LDO with pass-through mode
Hi E2E,
I would like to know if you have an LDO can allows current to pass through when VIN is lower than the  set output voltage.
Franz
  • Hi Franz,
    Normally we try to prevent reverse current as the allowed current conducted through the body diode of the LDO is much less than the rated maximum output current. Will you help to explain to us what you are trying to do in the application that needs the reverse current?
    Jason
