Hi Team,
Would you advise that
1.When a thermistor with a built-in battery is attached to pin 11 (TS terminal) of BQ34Z100PWR-G1,
how should the temperature detected by Fuel Gauge be obtained from this terminal voltage?
2. It is written in the specifications on page 37 that pin 11 has a pull-down circuit inside the IC,
but what is the internal resistance value of the pull-down?
Shidara
