Part Number: TPS3813
Hello Team,
May Customer is looking for the junction temperature of TPS3813. Can you share this with us?
Renan
Hello Team,
Renan
Hi Renan,
For this device we specify TA instead of Tj to allow customers to use the device in a higher TA.
If you need a Tj you can use the TA value because the device does not consume high power so you can assume Ta=Tj.
So TA max is 85C which can be understood as Tj (max) = ~85C
