Hey,
When is it beneficial to use a PMIC vs individual buck/LDOs. What are the downsides of each?
Hey,
Hello, here is some inputs using PMIC verses discrete solution
1- PMIC is more compact solution and it is beneficial for board space compared to discrete solution
2- PMIC is less expensive solution compared to discrete solution
3- PMIC solution has less parasitic impedances compared to discrete solution
4- Discrete solution has lower thermal impedance compared to PMIC because the parts are populated on larger surface area
5- Discrete solution is easier to debug compared to PMIC because there is access to each pin of the parts
