Hi TI Team,
I found that sometimes "Current" and "RunTimeToEmpty" are not updated at the same time. For example, when negative current appears, at that time, run time to empty is still 65535. This cause some confusing on our customer's host because when battery start to provide power to the host, at the beginning, remaining time in the host may show crazy large time (e.g. 1092 hours) because remaining time is read from run time to empty which is still 65535 at the moment. Can you please advise why there is such inconsistency between Current and RunTimeToEmpty?
Also attach the log data. Please kindly review on highlighted columns and row which point out the issue I mentioned above.
Zhihan
