Other Parts Discussed in Thread: LP5912, TLV767
For the special used, we want to co-layout TPS746, TLV767 and LP5912. Since the pin definition is different, we want to consult with you about the TPS746.
- May I connect the PG(Pin5) pin to GND(Pin3)?
- May I connect the NC(Pin2) pin to OUT(Pin1)?
- May I leave the GND(Pin3) open? But we will keep the Thermal-Pad in ground loop.
Thanks.
BR, Gary
