BQ27531-G1: Could you tell me why R25 is populated?
Guru 29720 points
Part Number: BQ27531-G1
Hi Team,
Regarding Figure 12, could you tell me why R25 is populated?
I believe R25 isn't required because the datasheet shows the following when external thermistor is used.
(datasheet page 11)
When an external thermistor is used, a 18.2-kΩ pullup resistor between the BI/TOUT and TS pins is also required.
