TPS51200: Inquiry about Pull-Up resistance value
Guru 12705 points
Part Number: TPS51200
My customer inquires about the selection of pull-up resistor values for PGOOD and EN of the TPS51200.
What is the appropiate resistance value for 3.3V pull-up voltage and how to determine it?
Thank you.
JH
  • Hi JH,
    The pull down resistance of PGOOD pin is <100 ohm. So depending on your logic level, you can select PGOOD pull up resistor 1k~100k. Of course with higher output you will have longer delay.
    EN is high impedance input, you can also select 1k~100k pull up resistance.
    With higher resistance the noise immunity will be worse. So this also needs to be considered depending on your system design.
    Weidong
