TPS22962: Inquiry about pull-down resistance value
Guru 11160 points
Part Number: TPS22962
My customer wants to use a pull-down resistor on the ON pin of the TPS22962.
What is the appropriate resistance value and how to determine it?
Thank you.
JH
  • Hi JH,
    The ON pin of the device is not a power pin but rather a control pin. This pin can be used with MCUs and other such controllers and hence heavy (low) pull down resistors can be used but are not necessary here. Standard values like 10k are acceptable.
