Hi Sir,
may i learn from you, the file attached below.
because the customer currently does not output +5v.
the transformer be the cause of this issue?
Hi Sir,
Yes the transformer could be cause.
Also we do not recommend diode flyback for 5V - we recommend sync flyback.
Also the linear voltage regulator should be low voltage reference (1.24V) otherwise it is turning on at 2.49V which is 50% of output voltage.
If this post answers your question, please indicate so by marking this thread as resolved. Thank you.
Michael P.
Applications Engineer
Texas Instruments
