HI
could you help check the TPS543B20 schematic as below and any need to adjust ?
HI
Hi GARETH OU,
Hi GARETH OU,
I just noticed that the 3.3V rail has 5V input. I would recommend reducing the switching frequency of that rail to <=750kHz to give some more margin to the converter's minimum off time of 250ns typical in datasheet. This would require RT=R4424 to change to approximately 26kohm.
