BQ24400: 3 Cell NiMH charger with USB-Power-Supply
Part Number: BQ24400
We have a design with BQ24400 to charge a 3 cell battery back (NiMH). The schematic is like the reference design in datasheet. Input voltage is 9 volt. Now the customer would like to change the input voltage to 5 volt from an USB power supply.
Is it possible to charge 3 cells with 5 volt (4.75min) input voltage?
If not, which device would you recommend to use for such application?
Thanks in advance.
