BQ35100: looking for a simple to use fuel gauge
Part Number: BQ35100
Hi Team,
my customer is looking for a simple to use fuel gauge (ideally no programming efforts needed).
The gauge should work on LiPo and primary cells.
Would BQ35100 be a good fit for this or could you recommend a better/simpler solution?
BR,
Stefan
  • Hello Stefan,
    All of our gauges will require some configuration before being used. Depending on the accuracy they want and what information they need from the gauge the bq35100 may work for them. It is our only primary cell gauge so if they need something that works with both Primary and LiPo they may need to use accumulator mode.
    Can you give more detail to the application? What chemistries they thinking of using, their load profile, battery capacity.
    Sincerely,
    Wyatt Keller
