Other Parts Discussed in Thread: BQ34Z100, GPCCHEM
Good morning,
I'm still facing with the problem of SOC jumping to zero. I'm using the BQ34Z100-G1 for monitoring a NiMH battery pack. I've selected exactly the right cell model from the database (I've been lucky to find it!) and I was testing the charge termination algorithm based on DT and DV.
During such a test I obtained several time a sudden SOC jump to zero. It happened more or less when I tried to heat up the NTC for checking the termination criteria. At the same time the Flags registers shows some reserved flags to switch active. Is it possible to understand reasons for such a behavior? I need to understand that in order to guarantee the BQ34Z100-G1 will be reliable.
Below it is possible to find the gg file and the log file.
Thank you and best regards
Matteo
