Hi Team,
Can you please explain what the "adj" value is that is located in the Fusion Digital Power Designer tool, monitor tab, and next to all the OVF/OVW/Vout/UVW/UVF values?
Why is the Vout adj value the only one that is equal to the value set and all the other fault and warning adj values are different than the setting?
While using the dual-phase TPS546D24A EVM with the GUI, the OVF/OVW/UVW/UVF lines in the Vout plot are all at the level of "adj" value instead of the value manually set. Why is the "adj" value being used?
No faults in writing to hardware.
Thank you,
Trenton Reed
