Other Parts Discussed in Thread: LM5050-1
I am using LM5050-1 (part number: LM5050Q1MK-1/NOPB) in an application where I want to power the chip from an external VS supply, as shown in the graphic below.
However, the VS supply will be at +12V when the product is "on," and when the product is "off" VS will be at 0 Volts.
The IN pin is connected to a Lithium-Ion battery pack, and the IN/OUT is connected with a MOSFET as described in the datasheet.
I would like to know how the LM5050 behaves when there is power on the IN/OUT pins, but VS is not powered. Will the chip draw any leakage current on the IN or OUT pins? In other words, will it drain my Lithium-ion battery when the product is on the "OFF" state?
Please let me know if this question is clear. Thank you.
