Other Parts Discussed in Thread: TPS54335A, TPS65131, LMR33630
Dear all,
can the TPS62913 be used to create a negative output voltage / inverting power supply like described in SLVA317B?
I would like to design a very low noise +/- 12V dual / split-rail supply and was wondering whether the TPS62913 can be used to design such a power supply (15-20V input) or would you rather suggest to use another regulator such as the TPS54335A followed by a ferrite bead and a LDO regulator (ultra low noise and output ripple are the most important aspects)?
Many thanks,
Sebastian
