Other Parts Discussed in Thread: BQ76930
Hi TI Team,
Is it advisable to conformal coat the BQ76940, BQ76930 series ICs. If yes, what must be thickness of conformal coating.
Thank you,
Rohan Patwardhan
Hi Rohan,
Conformal coating is really dependent on your application. If you expect moisture and dust, then it may be beneficial to protect the electronics on your PCB and prevent shorting between pins. I do not have any recommendation for conformal coating thickness.
Matt
