Hello support team,
Customer inquiries IRateAVG1 and IRateAVG2 definition. Could you explain what IRateAVG1 and IRateAVG2?
By referring TRM "7.4.2.3.10 Taper Rate, Taper Voltage", bq27426 detects charge termination by comparing them with Taper Rate, "IRateAvg1 < Taper Rate and IRateAvg2 < Taper Rate". However, they feel that these looks to be different factor, this makes them confused.
*Taper Rate: Taper Rate = Design Capacity / (0.1 × taper current) from Quick start guide. This seems to mean 10 times taper ratio, based on Design Capacity
* IRateAVG1 and IRateAVG2: 40-second periods average current. Unit of IRateAVG seems to be mAh or Coulomb.
Koji Ikeda
