Dear team,
May I learn from you the maximum Css value of TPS563210A?
Thanks.
Dear team,
Thanks.
Hi Ben,
Let us check on bench and feedback to you later. Does your customer have any concern about this Css value?
Hi ,
Normally TPS563210A can support 10mS max soft start time (82nF) . Please let us know if this data okay for customers .
We can also check on bench if customers want to use a larger Css.
BRs,
Young
Hi Young,
They would like to maintain power with supercap and want to control inrush current via SS funcion.
They want to use 1uF or higher Css for this application.
I will check it on EVM with supercap . And will share the results later .
BRs,
Young
Hi Young,
Thanks, customer use 7.5F supercap at TPS563210A output side. (6~12Vin to 4.2Vout)
Hi Ben,
I'm working on the test. Please help confirm that the max steady state current and start up loading .
As i find that tps563210A can startup under most conditions (<~2.9A startup loading) with 12Vin-1.05Vout .
Could you help share the SCH so i can configure the EVM as customers board to check the possibility .
BRs,
Young
Hi Ben,
update some test results. Condition 12Vin-4.5Vo with CSS 1uF on EVM (L changed to 3.3uH, Vo changed to 4.5V, Css changed to 1uF).
TPS563210A can start up well with 1UF Css cap . But at 3A loading start up , the SS time seems reduced to ~45ms .
Other SS time seems normal ~ 140ms.
1. 12Vin-4.5Vo _2A start up loading
2. 12Vin-4.5Vo _3A start up loading
BRs,
Young
