Hi Team,
Just want to check how much time is needed for EN to be pulled high to enable the part. There is application that customer want to use pulse to enable the part for short time and then disable the part. Thanks.
BRs
Given
Hi Team,
BRs
Given
Hi Given:
Customer use the EN pin or I2C to En/Disable the device?
Hi Minqiu,
Customer use EN pin. So they want to know min time for EN pin to pull high to enable the part. Thanks.
BRs
Given
Hi Given:
As we talked in the call, it's better to control the Enable/Disable status via the I2C. There is littler delay, almost the time for communication.
