Li-Poly Battery Charger with MPPT or variable charge current
Other Parts Discussed in Thread: BQ25798, BQ24650
Hi
I require a charge for a Li-Poly battery that will work well with a Solar panel. From my understanding, as the sunlight varies the charge current should also vary, otherwise, the voltage from the input would drop below the charger minimum working voltage? This would cause some form of pulse charging instead of a continuous charge.
Can you please recommend me what would be a suitable charger for such application?
Thank You
