Other Parts Discussed in Thread: TPS3899, TPS3808, TPS3890,
Could you provide ESD Ratings (ESD HBM Level and ESD CDM Level) of TPS3805H33? It is not written in the datasheet.
Hi Martin,
Getting the ESD data for this part may take some time. May I ask what is the application you are using the the TPS3805H33? We do have newer voltage detectors available if you are deciding which detector works for your application. Would the TPS3890, TPS3899, or TPS3808 work for your application?
Ben
