Lithium batteries. Necessary high voltage - connected in series, you need to recharge, and equalize the charges - connected in parallel. It is strange, why this method is not used. Make such a switch is easy to MOSFET or relay. If you want a permanent presence of voltage from the battery, you can make two identical blocks. One is on duty, the other charged or equalized.
