TPS7A16-Q1: Question about minimum Cout value
Part Number: TPS7A16-Q1
Hi Experts
My customer has a question about the minimum Cout value.
Is the absolute minimum for Cout 2.2uF, ie. they should choose a part with a nominal value >2.2uF?
Or can they use a nominal 2.2 uF ceramic capacitor with normal tolerances and temperature coefficients etc. and will that be sufficient for stability?
Thanks!
Jim B
  • Hi Jim,
    A nominal 2.2-uF ceramic capacitor will satisfy the requirement for the output capacitor. But for better AC performance, a 10-uF is recommended. For newer datasheet, we have differentiated the difference between capacitor and capacitance; when you see minimum capacitance, the capacitor needs to provide the capacitance with degrading.
    Jason Song
