HELLO TI PEOPLE
IM USING A TPS60400 FOR SUPPLYING A Instrumentation Amplifier with -3,7V but im having a problem in the output signal after doing filters and gain im seeing in the signal the output ripple voltage of tps60400, i have read the datasheet and i put the post filter rc and rlc that you recommend but im still having this ripple. so i was wondering if is any form to eliminate or deacrease this ripple. if this is not posible is any other ICs that can use for supply negative voltage with out this output ripple voltage
thank you for your attention
