Dear Support team,
It turned out that when CFGUPMODE is True, the value of Remaining Capacity is considerably different from the ideal value.
Could you let me confirm below things.
1. Is there a possibility that Remaining Capacity will not be counted normally in the situation where the write command is not issued and the Standard Command is read only during CFGUPMODE?
2. Is it possible that the SEALED / UNSEAL status affects the Remaining Capacity calculation regardless CFGUPMODE conditions?
3. Please let me know if there is any other possibility that Remaining Capacity may not be calculated / integrated normally.
Hirokazu Takahashi
