Other Parts Discussed in Thread: TPS7A20, TPS2121, TPS2113A, TPS2115A
Hello All,
We are designing a battery operated system which will have a back-up power supply using USB when battery is down.
For this we are using TPS22933 Power Multiplexer, after studying the data sheet of the same we observed that the output current of the IC is 50mA,Where as we require the output current up-to 300mA,
So we have decided to connect an LDO IC TPS7A20 at the output of the multiplexer which supplies required output current.
If used in such combination will it work?
We request you to please provide us your suggestion on the same at the earliest.
