Part Number: LM5122
Hi Team,
Need your clarifications for this query from our customer. The feedback transfer function of LM5122 was defined as -V_COMP / V_OUT on page 26 of the datasheet, which was the same with the feedback transfer function of Table 2. However, the open loop response formula on the same table does not have this negative sign. The function was positive instead. Can you help us with the reason for the difference? When simulating the system, should they use the positive or negative transfer function?
Thanks in advance!
Kind Regards,
Jejomar
