Part Number: UCC28710
Other Parts Discussed in Thread: UCC28711
Hey team,
I'm working with a customer to help fix a ringing issue they are seeing on the UCC28710 and we are working to design a snubber. Using the TI RCD Snubber Calculator we received the following, but wanted to double check how some values were supposed to be calculated. From measurements on the board they made, they see the UCC running at around 50kHz, does that make sense? They also are using the power rating as Vsnub^2/Rsnub which comes out to 8 Watts. Is this the correct equation for calculating power over the snub?
My thoughts are that based on https://e2e.ti.com/blogs_/b/powerhouse/archive/2016/05/05/calculate-an-r-c-snubber-in-seven-steps
