UCC2813-0: Webench design transformer spice model
Part Number: UCC2813-0
Other Parts Discussed in Thread: UCC28C40-Q1, UCC28C40
Webench created a schematic with a transformer. We would like to simulate the design with TINA spice 12, but need help setting up the transformer for the simulation.
  • David,
    Thanks for your interest in TI here. What sort of simulation are you trying to run and what are you hoping to learn from it? Are you trying to verify the selection of transformer parameters for the design?
    Please share your webench design information as well so we better understand your specifications.
    John
  • Here is the output from Webench:
    How do you create the transformer in Tina for the following?
  • I just got back in to see if there were any comments added and noticed that schematic I cut and pasted is not showing up. I'm trying again by converting the Webench output to a Word document.
    WEBENCH ®     Design Report
    Design : 14 UCC2813DTR-0
    UCC2813DTR-0 10V-264V to 12.00V @ 1A
    VinMin = 10.0V VinMax = 264.0V Vout = 12.0V Iout = 1.0A
    Device = UCC2813DTR-0
    Topology = Flyback
    Created = 2021-01-13 14:52:35.171 BOM Cost = NA
    BOM Count = 45 Total Pd =
    Dsec2
    VF@Io= 500.0 m V
    VRRM= 666.977 V
    T1
    Dsec
    VF@Io= 500.0 m V
    VRRM= 666.977 V
         Vin
    Cin
    2.2 µF
    14.0 m Ohm
    Rstartup1
    4.7 kOhm
    250.0 m W
    Rsnub2
    1.2 kOhm
    2.0 W
    Rsnub1
    1.2 kOhm
    2.0 W
    Csnub
    180.0 nF
    1.0 m Ohm
    Dsnub
    VF@Io= 1.0 V
    VRRM= 400.0 V
    Cout 1
    180.0 µF
    16.0 m Ohm
    Iout
    Cref
    100.0 nF
    1.0 m Ohm
    UCC2813 - 0 D
    Rstartup2
    4.7 kOhm
    250.0 m W
    C12
    100.0 nF
    64.0 m Ohm
    Cvcc
    33.0 µF
    700.0 m Ohm
    Raux
    10.0 Ohm
    63.0 m W
    Daux
    VF@Io= 500.0 m V
    VRRM= 503.488 V
    Rz
    1.1 kOhm
    63.0 m W
    Q1
    Rfbt
    Ct
    1.0 nF
    25.0 m Ohm
    Qsc
    C13
    1.0 nF
    REF
    RC
    FB U1 COMP CS
    VCC
    OUT
    GND
    Rdrv
    12.1 Ohm
    63.0 m W
    M1
    VdsMax= 356.0 V IdsMax= 6.0 Amps
    13.7 kOhm
    63.0 m W
    Dz
    Rt
    15.4 kOhm
    50.0 m W
    Rsc
    3.24 kOhm
    63.0 m W
    R11
    10.0 kOhm
    50.0 m W
    Ccs
    470.0 pF
    Rcs
    1000.0 Ohm
    63.0 m W
    Rsns
    167.617 m Ohm
    0.0 W
    Rled
    1.21 kOhm
    63.0 m W
    Rbias
    4.87 kOhm
    63.0 m W
    R21
    10.0 kOhm
    50.0 m W
    D21
    VF@Io= 550.0 m V
    VRRM= 30.0 V
    C21
    22.0 µF
    2.05 m Ohm
    C22
    22.0 pF
    R13
    4.99 kOhm
    63.0 m W
    O1        R22
    2.49 MOhm
    63.0 m W
    C23
    1.23429 pF
    R12
    1.43 kOhm
    63.0 m W
    VR
    Rfbb
    3.6 kOhm
    100.0 m W
    Design Alerts
    Component Selection Information
    Click on the transformer symbol in the schematic and select "Explore Transformer Core/Bobbin Selection" to design using specific transformer cores and bobbin. With the current design condition, suitable FET could not be found in the current database. Hence, this design is created using an ideal FET. Please note that the resulting FET parameters are ideal, so the efficiency/loss values have been disabled. Also, the schematic/PCB export and Thermal simulations will not work with the ideal FET.
    Electrical BOM
    Name
    Manufacturer
    Part Number
    Properties
    Qty
    Price
    Footprint
    C12
    Kemet
    C0805C104M5RACTU
    Cap= 100.0 nF
    1
    $0.01
    Series= X7R
    ESR= 64.0 mOhm
    VDC= 50.0 V
    0805 7 mm2
    IRMS= 1.64 A
    C13
    MuRata
    GRM1555C1H102JA01J
    Cap= 1.0 nF
    1
    $0.01
    Series= C0G/NP0
    VDC= 50.0 V
    IRMS= 0.0 A
    0402 3 mm2
    C21
    TDK
    C2012X5R1V226M125AC
    Cap= 22.0 uF
    1
    $0.33
    Series= X5R
    ESR= 2.05 mOhm
    VDC= 35.0 V
    0805 7 mm2
    IRMS= 4.5559 A
    C22
    Samsung Electro-
    CL21C220JBANNNC
    Cap= 22.0 pF
    1
    $0.01
    Mechanics
    Series= C0G/NP0
    VDC= 50.0 V
    IRMS= 0.0 A
    0805 7 mm2
    C23
    CUSTOM
    CUSTOM
    Cap= 1.23429 pF
    1
    NA
    Series= ?
    VDC= 0.0 V
    IRMS= 0.0 A
    CUSTOM 0 mm2
    Ccs
    AVX
    04025A471JAT2A
    Cap= 470.0 pF
    1
    $0.01
    Series= C0G/NP0
    VDC= 50.0 V
    IRMS= 0.0 A
    0402 3 mm2
    Name         Manufacturer                     Part Number                                   Properties                      Qty Price       Footprint
    Cin             TDK                                   B32674D4225K
    Series= B32674
    Cap= 2.2 uF
    ESR= 14.0 mOhm
    VDC= 450.0 V
    IRMS= 6.0 A
    1       $0.94
    CAPRR2750W80L3150T1250H2150
    486 mm2
    Cout1         Panasonic                         25SVPF180M Series= SVPF
    Cref            MuRata                              GRM155R71C104KA88D
    Series= X7R
    Csnub        MuRata                              GRM188R71E184KA88D
    Series= X7R
    Ct               Kemet                                 C0805C102J1GACTU
    Series= C0G/NP0
    Cvcc          Panasonic                         EEE-FK1E330UR Series= FK
    Cap= 180.0 uF
    ESR= 16.0 mOhm
    VDC= 25.0 V
    IRMS= 4.65 A
    Cap= 100.0 nF
    ESR= 1.0 mOhm
    VDC= 16.0 V
    IRMS= 0.0 A
    Cap= 180.0 nF
    ESR= 1.0 mOhm
    VDC= 25.0 V
    IRMS= 0.0 A
    Cap= 1.0 nF
    ESR= 25.0 mOhm
    VDC= 100.0 V
    IRMS= 1.71 A
    Cap= 33.0 uF
    ESR= 700.0 mOhm
    VDC= 25.0 V
    IRMS= 160.0 mA
    1       $0.63
    1       $0.01
    1       $0.03
    1       $0.09
    1       $0.09
    CAPSMT_62_E12 106 mm2
    0402 3 mm2
    0603 5 mm2
    0805 7 mm2
    SM_RADIAL_C 62 mm2
    D21            Panasonic                         DB2S31600L                                  VF@Io= 550.0 mV VRRM= 30.0 V
    Daux          CUSTOM                              CUSTOM                                          VF@Io= 500.0 mV VRRM= 503.488 V
    Dsec          CUSTOM                              CUSTOM                                          VF@Io= 500.0 mV VRRM= 666.977 V
    Dsec2        CUSTOM                           CUSTOM                                       VF@Io= 500.0 mV VRRM= 666.977 V
    Dsnub        SMC Diode Solutions        UF4004TA                                      VF@Io= 1.0 V VRRM= 400.0 V
    1       $0.03
    1       NA
    1       NA
    1       NA
    1       $0.22
    SOD-523 5 mm2
    CUSTOM 0 mm2
    CUSTOM 0 mm2
    CUSTOM 0 mm2
    DO-41 43 mm2
    Dz               ON Semiconductor            MMBZ5239BLT1G                         Zener                             1       $0.02
    M1              NA                                      IdealFET                                           VdsMax= 356.0 V IdsMax= 6.0 Amps
    1       NA
    SOT-23 14 mm2
    NA 0 mm2
    O1              Fairchild Semiconductor    FOD817A                                       Optocoupler                   1       $0.11
    Q1              Diodes Inc.                        MMBT4401-7-F                              Bipolar Transistor          1       $0.02
    DIP-4 71 mm2
    Qsc            STMicroelectronics            2N2222A                                        Bipolar Transistor          1       $1.11
    SOT-23 14 mm2
    R11            Yageo                                RC0201FR-0710KL
    Series= ?
    R12            Vishay-Dale                       CRCW04021K43FKED
    Series= CRCW..e3
    R13            Vishay-Dale                       CRCW04024K99FKED
    Series= CRCW..e3
    Res= 10.0 kOhm
    Power= 50.0 mW
    Tolerance= 1.0%
    Res= 1.43 kOhm
    Power= 63.0 mW
    Tolerance= 1.0%
    Res= 4.99 kOhm
    Power= 63.0 mW
    Tolerance= 1.0%
    1       $0.01
    1       $0.01
    1       $0.01
    TO-18 57 mm2
    0201 2 mm2
    0402 3 mm2
    0402 3 mm2
    R21            Yageo                                RC0201FR-0710KL
    Series= ?
    R22            Vishay-Dale                       CRCW04022M49FKED
    Series= CRCW..e3
    Raux          Vishay-Dale                       CRCW040210R0FKED Series= CRCW..e3
    Rbias         Vishay-Dale                       CRCW04024K87FKED Series= CRCW..e3
    Rcs            Vishay-Dale                       CRCW04021K00FKED Series= CRCW..e3
    Rdrv           Vishay-Dale                       CRCW040212R1FKED Series= CRCW..e3
    Rfbb           Yageo                                RC0603FR-073K6L
    Series= ?
    Rfbt            Vishay-Dale                       CRCW040213K7FKED Series= CRCW..e3
    Rled           Vishay-Dale                       CRCW04021K21FKED Series= CRCW..e3
    Rsc            Vishay-Dale                       CRCW04023K24FKED Series= CRCW..e3
    Rsns          CUSTOM                              CUSTOM
    Series= ?
    Rsnub1      Vishay-Bccomponents       PR02000201201JR500
    Series= ?
    Rsnub2      Vishay-Bccomponents       PR02000201201JR500
    Series= ?
    Rstartup1 Yageo                                RC1206FR-074K7L Series= ?
    Rstartup2 Yageo                                RC1206FR-074K7L Series= ?
    Rt               Yageo                                RC0201FR-0715K4L
    Series= ?
    Rz               Vishay-Dale                       CRCW04021K10FKED Series= CRCW..e3
    Res= 10.0 kOhm
    Power= 50.0 mW
    Tolerance= 1.0%
    Res= 2.49 MOhm
    Power= 63.0 mW
    Tolerance= 1.0%
    Res= 10.0 Ohm
    Power= 63.0 mW
    Tolerance= 1.0%
    Res= 4.87 kOhm
    Power= 63.0 mW
    Tolerance= 1.0%
    Res= 1000.0 Ohm
    Power= 63.0 mW
    Tolerance= 1.0%
    Res= 12.1 Ohm
    Power= 63.0 mW
    Tolerance= 1.0%
    Res= 3.6 kOhm
    Power= 100.0 mW
    Tolerance= 1.0%
    Res= 13.7 kOhm
    Power= 63.0 mW
    Tolerance= 1.0%
    Res= 1.21 kOhm
    Power= 63.0 mW
    Tolerance= 1.0%
    Res= 3.24 kOhm
    Power= 63.0 mW
    Tolerance= 1.0%
    Res= 167.617 mOhm
    Power= 0.0 W
    Tolerance= 0.0%
    Res= 1.2 kOhm
    Power= 2.0 W
    Tolerance= 5.0%
    Res= 1.2 kOhm
    Power= 2.0 W
    Tolerance= 5.0%
    Res= 4.7 kOhm
    Power= 250.0 mW
    Tolerance= 1.0%
    Res= 4.7 kOhm
    Power= 250.0 mW
    Tolerance= 1.0%
    Res= 15.4 kOhm
    Power= 50.0 mW
    Tolerance= 1.0%
    Res= 1.1 kOhm
    Power= 63.0 mW
    Tolerance= 1.0%
    1       $0.01
    1       $0.01
    1       $0.01
    1       $0.01
    1       $0.01
    1       $0.01
    1       $0.01
    1       $0.01
    1       $0.01
    1       $0.01
    1       NA
    1       $0.05
    1       $0.05
    1       $0.01
    1       $0.01
    1       $0.01
    1       $0.01
    0201 2 mm2
    0402 3 mm2
    0402 3 mm2
    0402 3 mm2
    0402 3 mm2
    0402 3 mm2
    0603 5 mm2
    0402 3 mm2
    0402 3 mm2
    0402 3 mm2
    CUSTOM 0 mm2
    PR02 117 mm2
    PR02 117 mm2
    1206 11 mm2
    1206 11 mm2
    0201 2 mm2
    0402 3 mm2
    T1               Core=TDK ,
    CoilFormer=TDK
    Core=B65807J0000R041 ,
    CoilFormer=B65808E1508T001
    Lp= 18.0 µH
    Turns Ratio(Nas)= 7:9
    Turns Ratio(Nps)= 9:9
    Npri= 9.0
    Naux= 7.0
    Nsec= 9.0
    1       $1.38
    TDK_B65803 341 mm2
    Name
    Manufacturer
    Part Number
    Properties
    Qty
    Price
    Footprint
    U1
    Texas Instruments
    UCC2813DTR-0
    Switcher
    1
    $0.87
    VR              Texas Instruments             TL431IDBVR                                  Voltage References       1       $0.06
    D0008A 57 mm2
    R-PDSO-G3 16 mm2
    0 .2275
    Snubber Pd
    Duty Cycle
    60
    0 .2250        55
    0 .2225        50
    0 .2200        45
    0 .2175
    40
    0 .2150
    35
    0 .2125
    30
    0 .2100
    0 .2075        25
    0 .2050        20
    0 .2025        15
    0 .2000
    0 .1975
    0 .1950
    0 .1         0 .2         0 .3         0 .4         0 .5         0 .6         0 .7          0 .8         0 .9         1 .0
    Output Current (A)
    Vin= 10 .0 V   Vin= 137 .0 V   Vin= 264 .0 V
    Tsw
    10
    5
    0
    4 .25
    Output Current (A)
    T1 Iprim pk
    10 .266666671
    10 .266666670
    10 .266666669
    10 .266666668
    10 .266666667
    10 .266666666
    10 .266666665
    4 .00
    3 .75
    3 .50
    3 .25
    3 .00
    2 .75
    2 .50
    2 .25
    2 .00
    10 .266666664
    1 .75
    10 .266666663
    10 .266666662
    Output Current (A)
    1 .50
    1 .25
    1 .00
    Output Current (A)
    Vout pp percentage
    T1 Is1 RMS
    0 .500
    0 .475
    0 .450
    0 .425
    0 .400
    0 .375
    0 .350
    0 .325
    0 .300
    0 .275
    0 .250
    0 .225
    0 .200
    0 .175
    0 .150
    1 .8
    1 .7
    1 .6
    1 .5
    1 .4
    1 .3
    1 .2
    1 .1
    1 .0
    0 .9
    0 .8
    0 .7
    0 .6
    0 .5
    0 .4
    0 .3
    0 .2
    1 .5
    1 .4
    1 .3
    1 .2
    1 .1
    1 .0
    0 .9
    0 .8
    0 .7
    0 .6
    0 .5
    0 .4
    0 .3
    0 .2
    0 .1
    0 .0
    Output Current (A)
    Ipri Avg
    Output Current (A)
    Rfb Pd
    3 .50
    3 .25
    3 .00
    2 .75
    2 .50
    2 .25
    2 .00
    1 .75
    1 .50
    1 .25
    1 .00
    0 .75
    0 .50
    Output Current (A)
    Iout_DCM
    Output Current (A)
    Isec Ripple
    0 .008323705
    0 .008323704
    0 .008323703
    0 .008323702
    3 .75
    3 .50
    3 .25
    3 .00
    0 .008323701
    2 .75
    0 .008323700
    2 .50
    0 .008323699
    0 .008323698
    0 .008323697
    0 .008323696
    2 .25
    2 .00
    1 .75
    1 .50
    1 .25
    0 .008323695
    Output Current (A)
    Output Current (A)
    0 .0625
    0 .0600
    0 .0575
    0 .0550
    0 .0525
    0 .0500
    0 .0475
    0 .0450
    0 .0425
    0 .0400
    0 .0375
    0 .0350
    0 .0325
    0 .0300
    0 .0275
    0 .0250
    0 .0225
    0 .0200
    0 .0175
    Vout p- p
    Output Current (A)
    T1 Core Loss
    1 .5
    1 .4
    1 .3
    1 .2
    1 .1
    1 .0
    0 .9
    0 .8
    0 .7
    0 .6
    0 .5
    0 .4
    0 .3
    0 .2
    Cout1 IRMS
    Output Current (A)
    Ipri ripple pk- pk percentage
    0 .60
    0 .55
    0 .50
    0 .45
    0 .40
    0 .35
    0 .30
    0 .25
    0 .20
    0 .15
    0 .10
    0 .05
    0 .00
    2 .00
    1 .75
    1 .50
    1 .25
    1 .00
    0 .75
    0 .50
    0 .25
    0 .00
    Output Current (A)
    T1 Iprim RMS
    Output Current (A)
    200
    195
    190
    185
    180
    175
    170
    165
    160
    155
    150
    145
    140
    135
    130
    125
    120
    115
    5 .50
    5 .25
    5 .00
    4 .75
    4 .50
    4 .25
    4 .00
    3 .75
    3 .50
    3 .25
    3 .00
    2 .75
    2 .50
    2 .25
    2 .00
    1 .75
    1 .50
    1 .25
    Output Current (A)
    Toff
    Output Current (A)
    8 ,500
    8 ,000
    7 ,500
    7 ,000
    6 ,500
    6 ,000
    5 ,500
    5 ,000
    4 ,500
    4 ,000
    3 ,500
    3 ,000
    2 ,500
    2 ,000
    1 ,500
    1 ,000
    500
    0
    0 .0425
    0 .0400
    0 .0375
    0 .0350
    0 .0325
    0 .0300
    0 .0275
    0 .0250
    0 .0225
    0 .0200
    0 .0175
    0 .0150
    0 .0125
    0 .0100
    0 .0075
    0 .0050
    0 .0025
    0 .0000
    Tdead
    Output Current (A)
    Cin Pd
    Output Current (A)
    Dsec Vf
    6 .0
    5 .5
    5 .0
    4 .5
    4 .0
    3 .5
    3 .0
    2 .5
    2 .0
    1 .5
    1 .0
    0 .5
    0 .0
    0 .250
    0 .225
    0 .200
    0 .175
    0 .150
    0 .125
    0 .100
    0 .075
    0 .050
    0 .025
    Ton Act
    Output Current (A)
    Dsec Pd
    Output Current (A)
    Rsns Pd
    0 .500000004
    0 .500000003
    0 .500000002
    0 .500000001
    0 .500000000
    0 .499999999
    0 .499999998
    0 .499999997
    0 .499999996
    0 .499999995
    Output Current (A)
    0 .75
    0 .70
    0 .65
    0 .60
    0 .55
    0 .50
    0 .45
    0 .40
    0 .35
    0 .30
    0 .25
    0 .20
    0 .15
    0 .10
    0 .05
    0 .00
    Output Current (A)
    7 .0
    6 .5
    6 .0
    5 .5
    5 .0
    4 .5
    4 .0
    3 .5
    3 .0
    2 .5
    2 .0
    1 .5
    1 .0
    0 .5
    Pd Rstartup
    Pout
    12
    11
    10
    9
    8
    7
    6
    5
    4
    3
    2
    1
    0 .0
    Output Current (A)
    Dsec2 Pd
    Output Current (A)
    Dsec2 Vf
    0 .250
    0 .225
    0 .200
    0 .175
    0 .150
    0 .500000004
    0 .500000003
    0 .500000002
    0 .500000001
    0 .125
    0 .500000000
    0 .100
    0 .075
    0 .050
    0 .499999999
    0 .499999998
    0 .499999997
    0 .025
    0 .499999996
    1 .4
    1 .3
    1 .2
    1 .1
    Output Current (A)
    Iin Avg
    0 .499999995
    9 .722222227
    9 .722222226
    9 .722222225
    Output Current (A)
    Vaux
    1 .0
    0 .9
    0 .8
    0 .7
    0 .6
    0 .5
    0 .4
    0 .3
    0 .2
    0 .1
    9 .722222224
    9 .722222223
    9 .722222222
    9 .722222221
    9 .722222220
    9 .722222219
    9 .722222218
    0 .0
    Output Current (A)
    Output Current (A)
    21 .600000005
    Vsnub
    T1 Copper Loss
    21 .600000004
    0 .200
    21 .600000003
    0 .175
    21 .600000002
    0 .150
    21 .600000001
    21 .600000000
    21 .599999999
    21 .599999998
    0 .125
    0 .100
    0 .075
    21 .599999997
    0 .050
    21 .599999996
    0 .025
    21 .599999995
    0 .01425
    0 .01400
    0 .01375
    0 .01350
    0 .01325
    0 .01300
    0 .01275
    0 .01250
    0 .01225
    0 .01200
    0 .01175
    0 .01150
    0 .01125
    0 .01100
    0 .01075
    0 .01050
    0 .01025
    0 .01000
    0 .00975
    Output Current (A)
    Paux
    0 .000
    0 .0375
    0 .0350
    0 .0325
    0 .0300
    0 .0275
    0 .0250
    0 .0225
    0 .0200
    0 .0175
    0 .0150
    0 .0125
    0 .0100
    0 .0075
    0 .0050
    0 .0025
    0 .0000
    Output Current (A)
    Cout1 Pd
    4 .25
    4 .00
    3 .75
    3 .50
    3 .25
    3 .00
    2 .75
    2 .50
    2 .25
    2 .00
    1 .75
    1 .50
    Output Current (A)
    T1 Is1 pk
    3 .75
    3 .50
    3 .25
    3 .00
    2 .75
    2 .50
    2 .25
    2 .00
    1 .75
    1 .50
    Output Current (A)
    Ipri ripple
    1 .25
    1 .25
    1 .00
    Output Current (A)
    Output Current (A)
    0 .85
    0 .80
    0 .75
    0 .70
    0 .65
    0 .60
    0 .55
    0 .50
    0 .45
    0 .40
    0 .35
    0 .30
    0 .25
    0 .20
    0 .15
    0 .10
    0 .05
    0 .00
    T1 Pd
    Output Current (A)
    Operating Values
    Name
    Value
    Category
    Description
    1.
    Cin Pd
    41.143 mW
    Capacitor
    Input capacitor power dissipation
    2.
    Cout1 IRMS
    1.509 A
    Capacitor
    Output capacitor1 RMS ripple current
    3.
    Cout1 Pd
    36.415 mW
    Capacitor
    Output capacitor1 power dissipation
    4.
    Daux trr
    0.0 ns
    Diode
    Auxiliary Diode Reverse Recovery Time
    5.
    Dsec Pd
    250.0 mW
    Diode
    Secondary Diode Power Dissipation
    6.
    Dsec Vf
    500.0 mV
    Diode
    Effective Forward Voltage Drop at the Operating Current
    7.
    Dsec trr
    0.0 ns
    Diode
    Output Diode Reverse Recovery Time
    8.
    Dsec2 Pd
    250.0 mW
    Diode
    9.
    Dsec2 Vf
    500.0 mV
    Diode
    10.
    Dsnub trr
    50.0 ns
    Diode
    Snubber Diode Reverse Recovery Time
    11.
    ICThetaJA
    107.5 degC/W
    IC
    IC junction-to-ambient thermal resistance
    12.
    Iin Avg
    1.39 A
    IC
    Average input current
    13.
    Cin Pd
    41.143 mW
    Power
    14.
    Cout1 Pd
    36.415 mW
    Power
    15.
    Dsec Pd
    250.0 mW
    Power
    16.
    Dsec2 Pd
    250.0 mW
    Power
    17.
    Paux
    14.239 mW
    Power
    Power Dissipation in Raux and Daux
    18.
    Pd Rstartup
    5.254 µW
    Power
    Power Dissipation in Rstartup1 and Rstartup2
    19.
    Rfb Pd
    8.324 mW
    Power
    Rfb Power Dissipation
    20.
    Rsns Pd
    742.27 mW
    Power
    Current Limit Sense Resistor Power Dissipation
    21.
    Snubber Pd
    226.354 mW
    Power
    Snubber Power Dissipation
    22.
    T1 Copper Loss
    182.09 mW
    Power
    Transformer Copper Loss Power Dissipation
    23.
    T1 Core Loss
    182.09 mW
    Power
    Transformer Core Loss Power Dissipation
    24.
    T1 Pd
    364.18 mW
    Power
    Estimated Losses in Transformer
    25.
    Pd Rstartup
    5.254 µW
    Resistor
    26.
    Rfb Pd
    8.324 mW
    Resistor
    27.
    Rsns Pd
    742.27 mW
    Resistor
    28.
    BOM Count
    45
    System
    Total Design BOM count
    Information
    29.
    Duty Cycle
    57.479 %
    System
    Duty cycle
    Information
    30.
    FootPrint
    1.738 k mm2
    System Information
    Total Foot Print Area of BOM components
    31.
    Frequency
    97.403 kHz
    System
    Switching frequency
    Information
    32.
    Iout
    1.0 A
    System
    Iout operating point
    Information
    33.
    Iout_DCM
    708.622 mA
    System
    Approximate Current below which DCM mode of operation will begin
    Information
    34.
    Mode
    CCM
    System
    Conduction Mode
    Information
    35.
    Pout
    12.0 W
    System
    Total output power
    Information
    36.
    Tdead
    0.0 ns
    System
    Approximate Dead Time of the Regulator
    Information
    37.
    Toff
    3.909 us
    System
    Approximate Converter Off Time
    Information
    38.
    Ton Act
    5.901 us
    System
    Approximate Converter On Time
    Information
    39.
    Total BOM
    NA
    System
    Total BOM Cost
    Information
    Name
    Value
    Category
    Description
    40.
    Tsw
    10.267 us
    System
    Switching Time Period
    Information
    41.
    Vin
    10.0 V
    System
    Vin operating point
    Information
    42.
    Vout
    12.0 V
    System
    Operational Output Voltage
    Information
    43.
    Vout Actual
    11.99 V
    System
    Vout Actual calculated based on selected voltage divider resistors
    Information
    44.
    Vout Tolerance
    1.926 %
    System
    Vout Tolerance based on IC Tolerance (no load) and voltage divider
    Information
    resistors if applicable
    45.
    Vout p-p
    49.817 mV
    System
    Peak-to-peak output ripple voltage
    Information
    46.
    Vout pp percentage
    415.138 m%
    System
    Output Voltage ripple percentage
    Information
    47.
    Vsnub
    21.6 V
    System
    Voltage Across the Snubber
    Information
    48.
    Ipri Avg
    1.509 A
    Transformer
    Average Current in Primary Winding over the complete Switching
    Period
    49.
    Ipri ripple
    3.114 A
    Transformer
    Ripple Current in the Primary Winding
    50.
    Ipri ripple pk-pk
    118.561 %
    Transformer
    Primary Current pk-pk ripple percentage(of Ipri avg during ton only)
    percentage
    51.
    Isec Ripple
    3.114 A
    Transformer
    Ripple Current in the Secondary Winding
    52.
    Paux
    14.239 mW
    Transformer
    53.
    T1 Copper Loss
    182.09 mW
    Transformer
    54.
    T1 Core Loss
    182.09 mW
    Transformer
    55.
    T1 Iprim RMS
    2.104 A
    Transformer
    Transformer Primary RMS Current
    56.
    T1 Iprim pk
    4.183 A
    Transformer
    Transformer Primary Peak Current
    57.
    T1 Is1 RMS
    1.81 A
    Transformer
    Transformer Secondary1 RMS Current
    58.
    T1 Is1 pk
    4.183 A
    Transformer
    Transformer Secondary1 Peak Current
    59.
    T1 Pd
    364.18 mW
    Transformer
    60.
    Vaux
    9.722 V
    Transformer
    Auxiliary Voltage
    Design Inputs
    Name
    Value
    Description
    Iout
    1.0
    Maximum Output Current
    VinMax
    264.0
    Maximum input voltage
    VinMin
    10.0
    Minimum input voltage
    Vout
    12.0
    Output Voltage
    base_pn
    UCC2813-0
    Base Product Number
    source
    DC
    Input Source Type
    Ta
    30.0
    Ambient temperature
    WEBENCH® Assembly
    Component Testing
    Some published data on components in datasheets such as Capacitor ESR and Inductor DC resistance is based on conservative values that will guarantee that the components always exceed the specification. For design purposes it is usually better to work with typical values. Since this data is not always available it is a good practice to measure the Capacitance and ESR values of Cin and Cout, and the inductance and DC resistance of L1 before assembly of the board. Any large discrepancies in values should be electrically simulated in WEBENCH to check for instabilities and thermally simulated in WebTHERM to make sure critical temperatures are not exceeded.
    Soldering Component to Board
    If board assembly is done in house it is best to tack down one terminal of a component on the board then solder the other terminal. For surface mount parts with large tabs, such as the DPAK, the tab on the back of the package should be pre-tinned with solder, then tacked into place
    by one of the pins. To solder the tab town to the board place the iron down on the board while resting against the tab, heating both surfaces simultaneously. Apply light pressure to the top of the plastic case until the solder flows around the part and the part is flush with the PCB. If the solder is not flowing around the board you may need a higher wattage iron (generally 25W to 30W is enough).
    Initial Startup of Circuit
    It is best to initially power up the board by setting the input supply voltage to the lowest operating input voltage 10.0V and set the input supply's current limit to zero. With the input supply off connect up the input supply to Vin and GND. Connect a digital volt meter and a load if needed
    to set the minimum Iout of the design from Vout and GND. Turn on the input supply and slowly turn up the current limit on the input supply. If the voltage starts to rise on the input supply continue increasing the input supply current limit while watching the output voltage. If the current increases on the input supply, but the voltage remains near zero, then there may be a short or a component misplaced on the board.
    Power down the board and visually inspect for solder bridges and recheck the diode and capacitor polarities. Once the power supply circuit is operational then more extensive testing may include full load testing, transient load and line tests to compare with simulation results.
    Load Testing
    The setup is the same as the initial startup, except that an additional digital voltmeter is connected between Vin and GND, a load is connected between Vout and GND and a current meter is connected in series between Vout and the load. The load must be able to handle at least rated output power + 50% ( 7.5 watts for this design). Ideally the load is supplied in the form of a variable load test unit. It can also be done in the form of suitably large power resistors. When using an oscilloscope to measure waveforms on the prototype board, the ground leads of the oscilloscope probes should be as short as possible and the area of the loop formed by the ground lead should be kept to a minimum. This will help reduce ground lead inductance and eliminate EMI noise that is not actually present in the circuit.
    WEBENCH® Transformer Report
    # Name                                         Value
    1. Core Part Number                     B65807J0000R041
    2. Core Manufacturer                    TDK
    3. Coil Former Part Number          B65808E1508T001
    4. Coil Former Manufacturer         TDK
    Transformer Electrical Diagram Primary
    Turns                            9.0
    AWG                             29.0
    Layers                           2.0
    Strands                         4.0
    Insulation Type             Heavy Insulated Magnet Wire
    Auxiliary
    Turns                            7.0
    AWG                             28.0
    Layers                           1.0
    Strands                         2.0
    Secondary
    Turns                            9.0
    AWG                             27.0
    Layers                          2.0
    Strands                        2.0
    Insulation Type             Triple Insulated
    Transformer Construction Diagram
    Winding Instruction
    Winding
    AWG
    Turns
    Winding Orientation
    Primary First 1/2.0
    29.0
    5
    Clockwise
    Auxiliary
    28.0
    7.0
    Counter Clockwise
    Triple Insulated Secondary
    27.0
    9.0
    Counter Clockwise
    Primary Second 1/2.0
    29.0
    4
    Clockwise
    Transformer Parameters
    # Name                                         Value
    1. Lpri                                            1.8E-5H
    2. Inductance Factor(Al)                217.0nH
    3. Npri                                             9.0
    4. Nsec                                          9.0
    5. Naux                                          7.0
    6. Core Type                                 RM6
    7. Core Material                            N41
    8. Bmax                                         0.22T
    9. Switching Frequency                 97.40kHz
    10. DMax                                         0.6
    11. Ipk(Primary)                              4.13A
    12. Irms(Primary)                            2.02A
    13. Ipk(Secondary)                             4.13A
    14. Irms(Secondary)                       1.65A
    Design Assistance
    1. Master key : 2CD6EBCA95555025[v1]
    2. UCC2813-0 Product Folder : http://www.ti.com/product/UCC2813%2D0 : contains the data sheet and other resources.
    Topology = Flyback
    Dsec2
    VF@Io= 500.0 m V
    VRRM= 666.977 V
    T1
    Dsec
    VF@Io= 500.0 m V
    VRRM= 666.977 V
         Vin
    Cin
    2.2 µF
    14.0 m Ohm
    Rstartup1
    4.7 kOhm
    250.0 m W
    Rsnub2
    1.2 kOhm
    2.0 W
    Rsnub1
    1.2 kOhm
    2.0 W
    Csnub
    180.0 nF
    1.0 m Ohm
    Dsnub
    VF@Io= 1.0 V
    VRRM= 400.0 V
    Cout 1
    180.0 µF
    16.0 m Ohm
    Iout
    Cref
    100.0 nF
    1.0 m Ohm
    UCC2813 - 0 D
    Rstartup2
    4.7 kOhm
    250.0 m W
    C12
    100.0 nF
    64.0 m Ohm
    Cvcc
    33.0 µF
    700.0 m Ohm
    Raux
    10.0 Ohm
    63.0 m W
    Daux
    VF@Io= 500.0 m V
    VRRM= 503.488 V
    Rz
    1.1 kOhm
    63.0 m W
    Q1
    Rfbt
    Ct
    1.0 nF
    25.0 m Ohm
    Qsc
    C13
    1.0 nF
    REF
    RC
    FB U1 COMP CS
    VCC
    OUT
    GND
    Rdrv
    12.1 Ohm
    63.0 m W
    M1
    13.7 kOhm
    63.0 m W
    Dz
    Rt
    15.4 kOhm
    50.0 m W
    Rsc
    3.24 kOhm
    63.0 m W
    R11
    10.0 kOhm
    50.0 m W
    Ccs
    470.0 pF
    Rcs
    1000.0 Ohm
    63.0 m W
    Rsns
    167.617 m Ohm
    0.0 W
    Rled
    1.21 kOhm
    63.0 m W
    Rbias
    4.87 kOhm
    63.0 m W
    R21
    10.0 kOhm
    50.0 m W
    D21
    VF@Io= 550.0 m V
    VRRM= 30.0 V
    C21
    22.0 µF
    2.05 m Ohm
    C22
    22.0 pF
    R13
    4.99 kOhm
    63.0 m W
    O1        R22
    2.49 MOhm
    63.0 m W
    C23
    1.23429 pF
    R12
    1.43 kOhm
    63.0 m W
    VR
    Rfbb
    3.6 kOhm
    100.0 m W
    Design Alerts
    Electrical BOM
    Name
    Manufacturer
    Part Number
    Properties
    Qty
    Price
    Footprint
    C12
    Kemet
    C0805C104M5RACTU
    Cap= 100.0 nF
    1
    $0.01
    Series= X7R
    ESR= 64.0 mOhm
    VDC= 50.0 V
    0805 7 mm2
    IRMS= 1.64 A
    C13
    MuRata
    GRM1555C1H102JA01J
    Cap= 1.0 nF
    1
    $0.01
    Series= C0G/NP0
    VDC= 50.0 V
    IRMS= 0.0 A
    0402 3 mm2
    C21
    TDK
    C2012X5R1V226M125AC
    Cap= 22.0 uF
    1
    $0.33
    Series= X5R
    ESR= 2.05 mOhm
    VDC= 35.0 V
    0805 7 mm2
    IRMS= 4.5559 A
    C22
    Samsung Electro-
    CL21C220JBANNNC
    Cap= 22.0 pF
    1
    $0.01
    Mechanics
    Series= C0G/NP0
    VDC= 50.0 V
    IRMS= 0.0 A
    0805 7 mm2
    C23
    CUSTOM
    CUSTOM
    Cap= 1.23429 pF
    1
    NA
    Series= ?
    VDC= 0.0 V
    IRMS= 0.0 A
    CUSTOM 0 mm2
    Ccs
    AVX
    04025A471JAT2A
    Cap= 470.0 pF
    1
    $0.01
    Series= C0G/NP0
    VDC= 50.0 V
    IRMS= 0.0 A
    0402 3 mm2
    Series= B32674
    Cap= 2.2 uF
    ESR= 14.0 mOhm
    VDC= 450.0 V
    IRMS= 6.0 A
    1       $0.94
    486 mm2
    Series= X7R
    Series= X7R
    Series= C0G/NP0
    Cap= 180.0 uF
    ESR= 16.0 mOhm
    VDC= 25.0 V
    IRMS= 4.65 A
    Cap= 100.0 nF
    ESR= 1.0 mOhm
    VDC= 16.0 V
    IRMS= 0.0 A
    Cap= 180.0 nF
    ESR= 1.0 mOhm
    VDC= 25.0 V
    IRMS= 0.0 A
    Cap= 1.0 nF
    ESR= 25.0 mOhm
    VDC= 100.0 V
    IRMS= 1.71 A
    Cap= 33.0 uF
    ESR= 700.0 mOhm
    VDC= 25.0 V
    IRMS= 160.0 mA
    1       $0.63
    1       $0.01
    1       $0.03
    1       $0.09
    1       $0.09
    0402 3 mm2
    0603 5 mm2
    0805 7 mm2
    SM_RADIAL_C 62 mm2
    1       $0.03
    1       NA
    1       NA
    1       NA
    1       $0.22
    SOD-523 5 mm2
    CUSTOM 0 mm2
    CUSTOM 0 mm2
    CUSTOM 0 mm2
    DO-41 43 mm2
    1       NA
    SOT-23 14 mm2
    NA 0 mm2
    DIP-4 71 mm2
    SOT-23 14 mm2
    Series= ?
    Series= CRCW..e3
    Series= CRCW..e3
    Res= 10.0 kOhm
    Power= 50.0 mW
    Tolerance= 1.0%
    Res= 1.43 kOhm
    Power= 63.0 mW
    Tolerance= 1.0%
    Res= 4.99 kOhm
    Power= 63.0 mW
    Tolerance= 1.0%
    1       $0.01
    1       $0.01
    1       $0.01
    TO-18 57 mm2
    0201 2 mm2
    0402 3 mm2
    0402 3 mm2
    Series= ?
    Series= CRCW..e3
    Series= ?
    Rsns          CUSTOM                              CUSTOM
    Series= ?
    Series= ?
    Series= ?
    Series= ?
    Res= 10.0 kOhm
    Power= 50.0 mW
    Tolerance= 1.0%
    Res= 2.49 MOhm
    Power= 63.0 mW
    Tolerance= 1.0%
    Res= 10.0 Ohm
    Power= 63.0 mW
    Tolerance= 1.0%
    Res= 4.87 kOhm
    Power= 63.0 mW
    Tolerance= 1.0%
    Res= 1000.0 Ohm
    Power= 63.0 mW
    Tolerance= 1.0%
    Res= 12.1 Ohm
    Power= 63.0 mW
    Tolerance= 1.0%
    Res= 3.6 kOhm
    Power= 100.0 mW
    Tolerance= 1.0%
    Res= 13.7 kOhm
    Power= 63.0 mW
    Tolerance= 1.0%
    Res= 1.21 kOhm
    Power= 63.0 mW
    Tolerance= 1.0%
    Res= 3.24 kOhm
    Power= 63.0 mW
    Tolerance= 1.0%
    Res= 167.617 mOhm
    Power= 0.0 W
    Tolerance= 0.0%
    Res= 1.2 kOhm
    Power= 2.0 W
    Tolerance= 5.0%
    Res= 1.2 kOhm
    Power= 2.0 W
    Tolerance= 5.0%
    Res= 4.7 kOhm
    Power= 250.0 mW
    Tolerance= 1.0%
    Res= 4.7 kOhm
    Power= 250.0 mW
    Tolerance= 1.0%
    Res= 15.4 kOhm
    Power= 50.0 mW
    Tolerance= 1.0%
    Res= 1.1 kOhm
    Power= 63.0 mW
    Tolerance= 1.0%
    1       $0.01
    1       $0.01
    1       $0.01
    1       $0.01
    1       $0.01
    1       $0.01
    1       $0.01
    1       $0.01
    1       $0.01
    1       $0.01
    1       NA
    1       $0.05
    1       $0.05
    1       $0.01
    1       $0.01
    1       $0.01
    1       $0.01
    0201 2 mm2
    0402 3 mm2
    0402 3 mm2
    0402 3 mm2
    0402 3 mm2
    0402 3 mm2
    0603 5 mm2
    0402 3 mm2
    0402 3 mm2
    0402 3 mm2
    CUSTOM 0 mm2
    PR02 117 mm2
    PR02 117 mm2
    1206 11 mm2
    1206 11 mm2
    0201 2 mm2
    0402 3 mm2
    T1               Core=TDK ,
    CoilFormer=TDK
    Lp= 18.0 µH
    Npri= 9.0
    Naux= 7.0
    Nsec= 9.0
    1       $1.38
    TDK_B65803 341 mm2
    Name
    Manufacturer
    Part Number
    Properties
    Qty
    Price
    Footprint
    U1
    Texas Instruments
    UCC2813DTR-0
    Switcher
    1
    $0.87
    D0008A 57 mm2
    R-PDSO-G3 16 mm2
    0 .2275
    Snubber Pd
    Duty Cycle
    60
    0 .2250        55
    0 .2225        50
    0 .2200        45
    0 .2175
    40
    0 .2150
    35
    0 .2125
    30
    0 .2100
    0 .2075        25
    0 .2050        20
    0 .2025        15
    0 .2000
    0 .1975
    0 .1950
    Output Current (A)
    Tsw
    10
    5
    0
    4 .25
    Output Current (A)
    T1 Iprim pk
    10 .266666671
    10 .266666670
    10 .266666669
    10 .266666668
    10 .266666667
    10 .266666666
    10 .266666665
    4 .00
    3 .75
    3 .50
    3 .25
    3 .00
    2 .75
    2 .50
    2 .25
    2 .00
    10 .266666664
    1 .75
    10 .266666663
    10 .266666662
    Output Current (A)
    1 .50
    1 .25
    1 .00
    Output Current (A)
    Vout pp percentage
    T1 Is1 RMS
    0 .500
    0 .475
    0 .450
    0 .425
    0 .400
    0 .375
    0 .350
    0 .325
    0 .300
    0 .275
    0 .250
    0 .225
    0 .200
    0 .175
    0 .150
    1 .8
    1 .7
    1 .6
    1 .5
    1 .4
    1 .3
    1 .2
    1 .1
    1 .0
    0 .9
    0 .8
    0 .7
    0 .6
    0 .5
    0 .4
    0 .3
    0 .2
    1 .5
    1 .4
    1 .3
    1 .2
    1 .1
    1 .0
    0 .9
    0 .8
    0 .7
    0 .6
    0 .5
    0 .4
    0 .3
    0 .2
    0 .1
    0 .0
    Output Current (A)
    Ipri Avg
    Output Current (A)
    Rfb Pd
    3 .50
    3 .25
    3 .00
    2 .75
    2 .50
    2 .25
    2 .00
    1 .75
    1 .50
    1 .25
    1 .00
    0 .75
    0 .50
    Output Current (A)
    Iout_DCM
    Output Current (A)
    Isec Ripple
    0 .008323705
    0 .008323704
    0 .008323703
    0 .008323702
    3 .75
    3 .50
    3 .25
    3 .00
    0 .008323701
    2 .75
    0 .008323700
    2 .50
    0 .008323699
    0 .008323698
    0 .008323697
    0 .008323696
    2 .25
    2 .00
    1 .75
    1 .50
    1 .25
    0 .008323695
    Output Current (A)
    Output Current (A)
    0 .0625
    0 .0600
    0 .0575
    0 .0550
    0 .0525
    0 .0500
    0 .0475
    0 .0450
    0 .0425
    0 .0400
    0 .0375
    0 .0350
    0 .0325
    0 .0300
    0 .0275
    0 .0250
    0 .0225
    0 .0200
    0 .0175
    Vout p- p
    Output Current (A)
    T1 Core Loss
    1 .5
    1 .4
    1 .3
    1 .2
    1 .1
    1 .0
    0 .9
    0 .8
    0 .7
    0 .6
    0 .5
    0 .4
    0 .3
    0 .2
    Cout1 IRMS
    Output Current (A)
    0 .60
    0 .55
    0 .50
    0 .45
    0 .40
    0 .35
    0 .30
    0 .25
    0 .20
    0 .15
    0 .10
    0 .05
    0 .00
    2 .00
    1 .75
    1 .50
    1 .25
    1 .00
    0 .75
    0 .50
    0 .25
    0 .00
    Output Current (A)
    T1 Iprim RMS
    Output Current (A)
    200
    195
    190
    185
    180
    175
    170
    165
    160
    155
    150
    145
    140
    135
    130
    125
    120
    115
    5 .50
    5 .25
    5 .00
    4 .75
    4 .50
    4 .25
    4 .00
    3 .75
    3 .50
    3 .25
    3 .00
    2 .75
    2 .50
    2 .25
    2 .00
    1 .75
    1 .50
    1 .25
    Output Current (A)
    Toff
    Output Current (A)
    8 ,500
    8 ,000
    7 ,500
    7 ,000
    6 ,500
    6 ,000
    5 ,500
    5 ,000
    4 ,500
    4 ,000
    3 ,500
    3 ,000
    2 ,500
    2 ,000
    1 ,500
    1 ,000
    500
    0
    0 .0425
    0 .0400
    0 .0375
    0 .0350
    0 .0325
    0 .0300
    0 .0275
    0 .0250
    0 .0225
    0 .0200
    0 .0175
    0 .0150
    0 .0125
    0 .0100
    0 .0075
    0 .0050
    0 .0025
    0 .0000
    Tdead
    Output Current (A)
    Cin Pd
    Output Current (A)
    Dsec Vf
    6 .0
    5 .5
    5 .0
    4 .5
    4 .0
    3 .5
    3 .0
    2 .5
    2 .0
    1 .5
    1 .0
    0 .5
    0 .0
    0 .250
    0 .225
    0 .200
    0 .175
    0 .150
    0 .125
    0 .100
    0 .075
    0 .050
    0 .025
    Ton Act
    Output Current (A)
    Dsec Pd
    Output Current (A)
    Rsns Pd
    0 .500000004
    0 .500000003
    0 .500000002
    0 .500000001
    0 .500000000
    0 .499999999
    0 .499999998
    0 .499999997
    0 .499999996
    0 .499999995
    Output Current (A)
    0 .75
    0 .70
    0 .65
    0 .60
    0 .55
    0 .50
    0 .45
    0 .40
    0 .35
    0 .30
    0 .25
    0 .20
    0 .15
    0 .10
    0 .05
    0 .00
    Output Current (A)
    7 .0
    6 .5
    6 .0
    5 .5
    5 .0
    4 .5
    4 .0
    3 .5
    3 .0
    2 .5
    2 .0
    1 .5
    1 .0
    0 .5
    Pd Rstartup
    Pout
    12
    11
    10
    9
    8
    7
    6
    5
    4
    3
    2
    1
    0 .0
    Output Current (A)
    Dsec2 Pd
    Output Current (A)
    Dsec2 Vf
    0 .250
    0 .225
    0 .200
    0 .175
    0 .150
    0 .500000004
    0 .500000003
    0 .500000002
    0 .500000001
    0 .125
    0 .500000000
    0 .100
    0 .075
    0 .050
    0 .499999999
    0 .499999998
    0 .499999997
    0 .025
    0 .499999996
    1 .4
    1 .3
    1 .2
    1 .1
    Output Current (A)
    Iin Avg
    0 .499999995
    9 .722222227
    9 .722222226
    9 .722222225
    Output Current (A)
    Vaux
    1 .0
    0 .9
    0 .8
    0 .7
    0 .6
    0 .5
    0 .4
    0 .3
    0 .2
    0 .1
    9 .722222224
    9 .722222223
    9 .722222222
    9 .722222221
    9 .722222220
    9 .722222219
    9 .722222218
    0 .0
    Output Current (A)
    Output Current (A)
    21 .600000005
    Vsnub
    T1 Copper Loss
    21 .600000004
    0 .200
    21 .600000003
    0 .175
    21 .600000002
    0 .150
    21 .600000001
    21 .600000000
    21 .599999999
    21 .599999998
    0 .125
    0 .100
    0 .075
    21 .599999997
    0 .050
    21 .599999996
    0 .025
    21 .599999995
    0 .01425
    0 .01400
    0 .01375
    0 .01350
    0 .01325
    0 .01300
    0 .01275
    0 .01250
    0 .01225
    0 .01200
    0 .01175
    0 .01150
    0 .01125
    0 .01100
    0 .01075
    0 .01050
    0 .01025
    0 .01000
    0 .00975
    Output Current (A)
    Paux
    0 .000
    0 .0375
    0 .0350
    0 .0325
    0 .0300
    0 .0275
    0 .0250
    0 .0225
    0 .0200
    0 .0175
    0 .0150
    0 .0125
    0 .0100
    0 .0075
    0 .0050
    0 .0025
    0 .0000
    Output Current (A)
    Cout1 Pd
    4 .25
    4 .00
    3 .75
    3 .50
    3 .25
    3 .00
    2 .75
    2 .50
    2 .25
    2 .00
    1 .75
    1 .50
    Output Current (A)
    T1 Is1 pk
    3 .75
    3 .50
    3 .25
    3 .00
    2 .75
    2 .50
    2 .25
    2 .00
    1 .75
    1 .50
    Output Current (A)
    Ipri ripple
    1 .25
    1 .25
    1 .00
    Output Current (A)
    Output Current (A)
    0 .85
    0 .80
    0 .75
    0 .70
    0 .65
    0 .60
    0 .55
    0 .50
    0 .45
    0 .40
    0 .35
    0 .30
    0 .25
    0 .20
    0 .15
    0 .10
    0 .05
    0 .00
    T1 Pd
    Output Current (A)
    Operating Values
    Name
    Value
    Category
    Description
    1.
    Cin Pd
    41.143 mW
    Capacitor
    2.
    Cout1 IRMS
    1.509 A
    Capacitor
    3.
    Cout1 Pd
    36.415 mW
    Capacitor
    4.
    Daux trr
    0.0 ns
    Diode
    5.
    Dsec Pd
    250.0 mW
    Diode
    6.
    Dsec Vf
    500.0 mV
    Diode
    7.
    Dsec trr
    0.0 ns
    Diode
    8.
    Dsec2 Pd
    250.0 mW
    Diode
    9.
    Dsec2 Vf
    500.0 mV
    Diode
    10.
    Dsnub trr
    50.0 ns
    Diode
    11.
    ICThetaJA
    107.5 degC/W
    IC
    12.
    Iin Avg
    1.39 A
    IC
    13.
    Cin Pd
    41.143 mW
    Power
    14.
    Cout1 Pd
    36.415 mW
    Power
    15.
    Dsec Pd
    250.0 mW
    Power
    16.
    Dsec2 Pd
    250.0 mW
    Power
    17.
    Paux
    14.239 mW
    Power
    18.
    Pd Rstartup
    5.254 µW
    Power
    19.
    Rfb Pd
    8.324 mW
    Power
    20.
    Rsns Pd
    742.27 mW
    Power
    21.
    Snubber Pd
    226.354 mW
    Power
    22.
    T1 Copper Loss
    182.09 mW
    Power
    23.
    T1 Core Loss
    182.09 mW
    Power
    24.
    T1 Pd
    364.18 mW
    Power
    25.
    Pd Rstartup
    5.254 µW
    Resistor
    26.
    Rfb Pd
    8.324 mW
    Resistor
    27.
    Rsns Pd
    742.27 mW
    Resistor
    28.
    BOM Count
    45
    System
    Information
    29.
    Duty Cycle
    57.479 %
    System
    Duty cycle
    Information
    30.
    FootPrint
    1.738 k mm2
    System Information
    31.
    Frequency
    97.403 kHz
    System
    Switching frequency
    Information
    32.
    Iout
    1.0 A
    System
    Information
    33.
    Iout_DCM
    708.622 mA
    System
    Information
    34.
    Mode
    CCM
    System
    Conduction Mode
    Information
    35.
    Pout
    12.0 W
    System
    Total output power
    Information
    36.
    Tdead
    0.0 ns
    System
    Information
    37.
    Toff
    3.909 us
    System
    Information
    38.
    Ton Act
    5.901 us
    System
    Information
    39.
    Total BOM
    NA
    System
    Total BOM Cost
    Information
    Name
    Value
    Category
    Description
    40.
    Tsw
    10.267 us
    System
    Information
    41.
    Vin
    10.0 V
    System
    Vin operating point
    Information
    42.
    Vout
    12.0 V
    System
    Information
    43.
    Vout Actual
    11.99 V
    System
    Information
    44.
    Vout Tolerance
    1.926 %
    System
    Information
    45.
    Vout p-p
    49.817 mV
    System
    Information
    46.
    Vout pp percentage
    415.138 m%
    System
    Information
    47.
    Vsnub
    21.6 V
    System
    Information
    48.
    Ipri Avg
    1.509 A
    Transformer
    Period
    49.
    Ipri ripple
    3.114 A
    Transformer
    50.
    Ipri ripple pk-pk
    118.561 %
    Transformer
    percentage
    51.
    Isec Ripple
    3.114 A
    Transformer
    52.
    Paux
    14.239 mW
    Transformer
    53.
    T1 Copper Loss
    182.09 mW
    Transformer
    54.
    T1 Core Loss
    182.09 mW
    Transformer
    55.
    T1 Iprim RMS
    2.104 A
    Transformer
    56.
    T1 Iprim pk
    4.183 A
    Transformer
    57.
    T1 Is1 RMS
    1.81 A
    Transformer
    58.
    T1 Is1 pk
    4.183 A
    Transformer
    59.
    T1 Pd
    364.18 mW
    Transformer
    60.
    Vaux
    9.722 V
    Transformer
    Auxiliary Voltage
    Design Inputs
    Name
    Value
    Description
    Iout
    1.0
    VinMax
    264.0
    VinMin
    10.0
    Vout
    12.0
    Output Voltage
    base_pn
    UCC2813-0
    Base Product Number
    source
    DC
    Input Source Type
    Ta
    30.0
    Ambient temperature
    WEBENCH® Assembly
    Component Testing
    Load Testing
    # Name                                         Value
    Turns                            9.0
    AWG                             29.0
    Layers                           2.0
    Strands                         4.0
    Auxiliary
    Turns                            7.0
    AWG                             28.0
    Layers                           1.0
    Strands                         2.0
    Secondary
    Turns                            9.0
    AWG                             27.0
    Layers                          2.0
    Strands                        2.0
    Winding Instruction
    Winding
    AWG
    Turns
    Winding Orientation
    Primary First 1/2.0
    29.0
    5
    Clockwise
    Auxiliary
    28.0
    7.0
    Counter Clockwise
    27.0
    9.0
    Counter Clockwise
    29.0
    4
    Clockwise
    # Name                                         Value
    1. Lpri                                            1.8E-5H
    3. Npri                                             9.0
    4. Nsec                                          9.0
    5. Naux                                          7.0
    6. Core Type                                 RM6
    8. Bmax                                         0.22T
    10. DMax                                         0.6
    Design Assistance
  • David,
    apologies. There is no file here. Could you try to reattach as word or jpg or pdf or similar?
    John
  • David,
    I believe you can print the webench design as a word or PDF. You may consider to reattach. it's quite difficult to read as plain text in this dialog box.
    Coming back to your original question though- what are you hoping to simulate exactly in SPICE environment? What type of behavior? And what trouble are you seeing previously when you try to do it?
    John
  • Hello John,
    Which button allows the pdf file to be attached. According to this GUI it accepts Word documents.
    We want to simulate the design over our operating temperature range, over our entire input range, and over our entire output load range. To do this, we need to know how to set up the TINA spice model for the transformer. We have been able to enter all of the other components.
    I could also send it to your email address.
    I just opened Webench again and put in the parameters and it spit out the same design.You could also do that to get the circuit.
    VinMin = 10.0V
    VinMax = 264.0V
    Vout = 12.0V
    Iout = 1.0A
    Topology = Flyback
    David R. Baum
  • David,
    I ran a webench design with newest generation of this product family UCC28C40. You could also use UCC28C40-Q1 as well if you have higher operating current requirements for example. It should be very similar to what you saw with UCC2813. Attached are my webench design report and xfmr design document.
    I recommends a TDK core and Bobbin here. If you see that there are xfmr parameters not included that you would like modelled in your Spice setup, like leakage inductance, or specific winding resistances, or other, it may be best to connect with TDK directly to get those additional parameters. Perhaps they even have a model block that you could leverage. A TDK contact I have is:
    Mike O'Toole <mike.o'toole@us.tdk.com>
    Please let me know if you have other questions.
    12W_flyback_xfmr_TI_UCC28C40.pdf
  • Hello John,
    Sorry for the late response. I have had an upper respiratory infection.
    Is it possible to get the TINA spice model for the transformer. Nobody here has ever set up a transformer in TINA spice. We normally use GeckoCircuits for power simulation, but GeckoCircuits doesn't have models for the UCC2813. If you could send me a simple TINA spice file with the transformer set up, that would be great.
  • David,
    I'm sorry to hear that. I hope you're feeling better. I'm going to ask an applications engineer to dig around for existing TINA spice models. Perhaps he has an example that would be useful for you to leverage and modify. Please expect a response by Friday.
    John
  • Hi David,
    Thanks for connecting through E2E. The TINA transformer model is represented as an "ideal transformer", compared to the Webench model which is trying to help you design a customer transformer. The transformer parameters listed from your Webench result will have to be lumped and represented in TINA. For example, the primary DC resistance is shown below as R12, secondary dc resistance is R18, transformer primary magnetizing inductance is modeled by L1 and if you wanted to simulate the effect of leakage inductance (not shown below) you could add a small series inductor at pin1 and/or pin 4. If you click on the transformer box, you see the only parameter we can enter is "RATIO" and this is where you need to use the turns ratio numbers from Webench. You could repeat this process for each additional winding.
    Steve M
