Other Parts Discussed in Thread: , BQ24259, TPS65218D0, TPS650250
Hi Team,
A customer is working on a design based on BeagleBone Black module that uses the TPS65217 as the power management IC for an AM3358BZCZ100 processor. However, the TPS65217 doesn't support enough charging current as recommended for his 1800mAH battery (900mAH charge rate is desired).
Additionally, he needs to provide 5V power for a USB port while operating off the battery which will require additional converter since 5V is not available from TPS65217 when operating off battery.
He would like to ask for alternative components to use in this application. I have checked our product lines but a similar device, TPS652170, can't meet the requirements. Can you please suggest an alternative solution.
Danilo
