Other Parts Discussed in Thread: EMB1428Q, BQ76PL455A, BQ79616
Dear Sir/ Madam,
can we use EMB1499Q & EMB1428Q with LTO battery balancing which voltage range 1.5V to 2.9V & 10A balancing current?
Please reply as soon as possible
Dear Sir/ Madam,
Ravikant,
Would you also use bq76pl455a as the battery monitor device or which monitor? It is possible, you can look at the datasheet accuracy and min voltage specs for certain voltage ranges. But we no longer recommend to use EMB devices as they are older/complex solution with limited support and recommend to look at bq79606a and bq79616 for battery monitor/balancers.
Taylor
