when connect MSP430F5529LP, it shows that fail to connect to device TPS65933X on I2C @0x60, LED is lighting when S2 on. is there any wrong connect or other cfg i need to change?
thank you
Can you please confirm the following?
Gerard
Scripting is described in Section 3.4 of the User's Guide (https://www.ti.com/lit/ug/slvubo3a/slvubo3a.pdf)
Based on your screenshot, your script has a syntax error that would prevent the script from working - note the red underline at "function main{". In Section 3.4 of the User's Guide you can see an example code block with the correct syntax, which includes parentheses: "function main () {"
Gerard
