LM5118: Pspice simulation convergence not working
Part Number: LM5118
**** CIRCUIT DESCRIPTION
******************************************************************************** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
*Libraries:
* Profile Libraries :
* Local Libraries :
.LIB "../../../gt13720-pspicefiles/lm5118_trans.lib"
.lib "nom.lib"
*Analysis directives:
.TRAN 0 1m 0 20n SKIPBP
.OPTIONS ADVCONV
.PROBE64 V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
.INC "..\SCHEMATIC1.net"
**** INCLUDING SCHEMATIC1.net ****
* source GT13720
C_C1 V_IN 0 4.7u TC=0,0
C_C2 V_IN 0 4.7u TC=0,0
C_C3 V_IN 0 1u TC=0,0
X_U1 V_IN N01932 N02110 V_IN N02827 N02938 N07445 N06744 SUPPLY_LV 0 0
+ N03843 LO N04064 N03687 HO N03509 0 LM5118_TRANS
R_R1 N01932 V_IN 100k TC=0,0
R_R2 0 N01932 24k TC=0,0
C_C4 0 N01932 47nF TC=0,0
R_R3 0 N02110 18k TC=0,0
C_C5 0 N02827 330pF TC=0,0
C_C6 N02938 0 100n TC=0,0
C_C7 N03509 0 1uF TC=0,0
D_D1 N03843 HO MBRA2H100T3G
D_D2 N03843 HO MBRA2H100T3G
D_D3 N04096 SUPPLY_LV MBRA2H100T3G
D_D4 N04096 SUPPLY_LV MBRA2H100T3G
C_C8 HO N04064 100nF TC=0,0
L_L1 HO N04096 33uH
C_C9 0 SUPPLY_LV 1n TC=0,0
C_C10 0 SUPPLY_LV 1n TC=0,0
C_C11 0 SUPPLY_LV 1n TC=0,0
C_C12 0 SUPPLY_LV 1n TC=0,0
C_C13 0 N03843 100pF TC=0,0
R_R6 0 N03843 50m TC=0,0
R_R8 N06744 SUPPLY_LV 7.15k TC=0,0
R_R9 0 N06744 1k TC=0,0
C_C14 N06744 SUPPLY_LV 470pF TC=0,0
C_C15 N06744 N07452 680pF TC=0,0
C_C16 N07452 N07445 22nF TC=0,0
R_R10 N06744 N07452 18K TC=0,0
X_M1 V_IN N03687 HO IPD20N03L_L1 PARAMS:
X_M2 N04096 LO 0 IPD20N03L_L1 PARAMS:
V_V1 V_IN 0 13Vdc
**** RESUMING Supply_LV_Simuli.cir ****
.END
**** 01/19/21 17:17:38 ****** PSpice 17.2.0 (March 2016) ****** ID# 0 ********
** Profile: "SCHEMATIC1-Supply_LV_Simuli" [ d:\gt13720\simulation and calculations\pspice\gt13720-pspicefiles\schematic1\supply_lv_
**** Diode MODEL PARAMETERS
MBRA2H100T3G
IS 129.210000E-06
N 2.9151
ISR 10.000000E-21
NR 4.995
IKF 2.1974
BV 100
IBV 100.000000E-06
RS 6.708600E-03
TT 1.000000E-09
CJO 130.030000E-12
VJ 1.0845
M .56595
EG 1.1449
XTI .05001
Reducing minimum delta to make the circuit converge.
ERROR(ORPSIM-15138): Convergence problem in Transient Analysis at Time = 94.33E-06.
Time step = 487.5E-21, minimum allowable step size = 1.000E-18
These voltages failed to converge:
V(N04096) = -15.29V \ 5.369V
V(X_U1.gateLO) = -2.210KV \ -3.000V
V(LO) = -2.207KV \ -1.844uV
V(X_U1.conv3) = 0V \ 19.15uV
V(X_M1.g1) = 643.97mV \ 5.369V
V(X_M1.g) = 643.97mV \ 5.369V
V(X_M1.s1) = 643.97mV \ 5.369V
V(X_M1.s) = 643.97mV \ 5.369V
V(X_M1.d1) = 8.276V \ 13.00V
V(X_M1.d2) = 8.276V \ 13.00V
V(X_M2.g1) = -10.00GV \ -281.53nV
V(X_M2.g) = -10.00GV \ -1.186uV
V(X_M2.s1) = -10.00GV \ 3.318uV
V(X_M2.s) = -10.00GV \ 3.314uV
V(X_M2.d1) = -10.00GV \ 5.369V
V(X_M2.d2) = -10.00GV \ 5.369V
V(X_M1.X1.d) = 8.276V \ 13.00V
V(X_M1.X1.ox) = 2.984V \ 7.708V
V(X_M1.X1.s) = 643.97mV \ 5.369V
V(X_M1.X1.edep) = 4.127V \ 8.851V
V(X_M1.X1.ox0) = 643.97mV \ 5.369V
V(X_M1.X1.d1) = 8.276V \ 13.00V
V(X_M1.X1.d2) = 8.276V \ 13.00V
V(X_M1.X1.d3) = 8.276V \ 13.00V
V(X_M2.X1.d) = -10.00GV \ 5.369V
V(X_M2.X1.ox) = -10.00GV \ 1.963V
V(X_M2.X1.s) = -10.00GV \ 3.312uV
V(X_M2.X1.edep) = -10.00GV \ 2.761V
V(X_M2.X1.ox0) = -10.00GV \ 1.460uV
V(X_M2.X1.d1) = -10.00GV \ 5.369V
V(X_M2.X1.d2) = -10.00GV \ 5.369V
V(X_M2.X1.d3) = -10.00GV \ 5.369V
V(X_M2.X1.a) = -10.15uV \ 65.08nV
V(X_M2.X1.b) = -17.47KV \ 55.50nV
V(X_M2.X1.c) = -17.47KV \ 55.50nV
These supply currents failed to converge:
I(X_U1.Errout) = -529.04A \ 724.91uA
I(X_M1.X1.E_Edg) = -2.825mA \ 874.41nA
I(X_M1.X1.E_Eds) = 2.828mA \ 2.427uA
I(X_M1.X1.E_Egs) = -2.826mA \ 16.72nA
I(X_M1.X1.E_E001) = -98.73nA \ -979.20pA
I(X_M2.X1.E_Edg) = 32.77KA \ -980.97nA
I(X_M2.X1.E_Eds) = 0A \ -2.654uA
I(X_M2.X1.E_Egs) = 0A \ -285.17nA
I(X_M2.X1.E_E001) = 17.47KA \ 9.58nA
I(X_M1.Lg) = -854.64nA \ -857.70nA
I(X_M1.Ls) = -2.512uA \ -2.515uA
I(X_M1.Ld) = 3.391uA \ 3.373uA
I(X_M2.Lg) = 1.026KA \ 695.81nA
I(X_M2.Ls) = 879.60A \ 2.946uA
I(X_M2.Ld) = 6.157KA \ -3.642uA
I(X_U1.V_FBoffs) = -232.83pA \ -92.37fA
I(X_U1.V_Iscs) = 0A \ 1.915nA
I(X_U1.V_ccsense2) = 976.56uA \ 935.91uA
I(X_U1.V_ccsense1) = 976.56uA \ 935.91uA
I(X_M1.X1.V_sense) = 3.391uA \ 3.373uA
I(X_M1.X1.V_sense2) = 7.654nA \ 56.53nA
I(X_M1.X1.V_sense3) = -98.73nA \ -979.20pA
I(X_M2.X1.V_sense) = 6.158KA \ -3.642uA
I(X_M2.X1.V_sense2) = 8.734KA \ -27.75nA
I(X_M2.X1.V_sense3) = 17.47KA \ 9.58nA
I(X_U1.H_stabilizeCS) = 0A \ -1.915nA
These devices failed to converge:
X_M2.X1.E_Edg X_M2.X1.E_Eds X_M2.X1.G_chan X_U1.M1L X_U1.M2L
Last node voltages tried were:
NODE VOLTAGE NODE VOLTAGE NODE VOLTAGE NODE VOLTAGE
( HO) 5.3685 ( LO)-2206.6000 ( V_IN) 13.0000 (N01932) .2574
(N02110) .0180 (N02827)-3.688E-09 (N02938) .0070 (N03509) 7.0000
(N03687) 5.3685 (N03843) 13.77E-06 (N04064) 6.7635 (N04096) -15.2850
(N06744) .0069 (N07445) .0069 (N07452) .0069 (X_M1.g) .6440
(X_M1.s) .6440 (X_M1.w)-27.00E-18 (X_M2.g)-10.00E+09 (X_M2.s)-10.00E+09
(X_M2.w)-27.00E-18 (X_M1.d1) 8.2755 (X_M1.d2) 8.2755
(X_M1.g1) .6440 (X_M1.s1) .6440
(X_M1.Tj) 27.0000 (X_M2.d1)-10.00E+09
(X_M2.d2)-10.00E+09 (X_M2.g1)-10.00E+09
(X_M2.s1)-10.00E+09 (X_M2.Tj) 27.0000
(X_U1.V7) 7.0000 (X_U1.CLK) .3000
(X_U1.CSi) .0180 (X_U1.CSo) .1977
(X_U1.DRV) 3.5000 (X_U1.loQ) 3.5000
(X_U1.tst) 0.0000 (SUPPLY_LV) 5.2708
(X_M1.X1.a)-114.0E-09 (X_M1.X1.b)-15.31E-09
(X_M1.X1.c)-15.31E-09 (X_M1.X1.d) 8.2755
(X_M1.X1.s) .6440 (X_M2.X1.a)-10.15E-06
(X_M2.X1.b)-17.47E+03 (X_M2.X1.c)-17.47E+03
(X_M2.X1.d)-10.00E+09 (X_M2.X1.s)-10.00E+09
(X_U1.CLK1) .3000 (X_U1.CSGi) .0182
(X_U1.loQN) 0.0000 (X_U1.PWMQ) 3.5000
(X_M1.X1.d1) 8.2755 (X_M1.X1.d2) 8.2755
(X_M1.X1.d3) 8.2755 (X_M1.X1.ox) 2.9835
(X_M2.X1.d1)-10.00E+09 (X_M2.X1.d2)-10.00E+09
(X_M2.X1.d3)-10.00E+09 (X_M2.X1.ox)-10.00E+09
(X_U1.conv3) 0.0000 (X_U1.CSout) .1977
(X_U1.HIrst) 3.5000 (X_U1.Lorst) 0.0000
(X_U1.oscQN) 3.5000 (X_U1.pkrmp) 5.4458
(X_U1.PWMQN) 0.0000 (X_U1.SSmax) .1569
(X_U1.SSmin) .0070 (X_U1.unsat) .0069
(X_M1.X1.ox0) .6440 (X_M2.X1.ox0)-10.00E+09
(X_U1.clkdly) .3000 (X_U1.CSoffs) .2000
(X_U1.curlim) 1.4500 (X_U1.CURrst) 0.0000
(X_U1.DRVdly) 3.5000 (X_U1.enable) .3000
(X_U1.erramp) .0069 (X_U1.gateHI) 2.3685
(X_U1.gateLO)-2209.6000 (X_U1.ground) 0.0000
(X_U1.LDOctl) 0.0000 (X_U1.logic1) 7.0000
(X_U1.Lorst2) 3.5000 (X_U1.maxerr) .7521
(X_U1.minTon) 0.0000 (X_U1.REGctl) 50.0000
(X_U1.regout) 7.0000 (X_U1.rstloQ) 0.0000
(X_U1.rstPWM) 0.0000 (X_U1.sawCTL) 0.0000
(X_U1.SCSctl) 1.0000 (X_U1.setloQ) .3000
(X_U1.setPWM) .3000 (X_U1.SSclmp) .1569
(X_U1.trigon) 0.0000 (X_U1.Vccgen) 7.0000
(X_U1.VccTST) 13.0000 (X_U1.Vccval) 7.0000
(X_U1.Vstart) .0013 (X_M1.X1.edep) 4.1269
(X_M2.X1.edep)-10.00E+09 (X_U1.endTonA) 19.0760
(X_U1.erramp1) .0069 (X_U1.initrst) 3.5000
(X_U1.triggen) 3.5000 (X_U1.trigger) 0.0000
(X_U1.trigoff) 0.0000 (X_U1.tst_int) 0.0000
(X_U1.endBOOST) -1.0000 (X_U1.sawtooth) 0.0000
(X_U1.SRampctl) 1.0000 (X_U1.XA6.YINT) 0.0000
(X_U1.XA7.YINT) 0.0000 (X_U1.XVCOA1.3) -3.7378
(X_U1.XVCOA1.4) -4.0000 (X_U1.XVCOA1.5) 4.0000
(X_U1.XVCOA1.6) 2.0000 (X_U1.XVCOA1.7) 2.0000
(X_U1.boostmode) 0.0000 (X_U1.bstCLKinv) 3.5000
(X_U1.bstminTon) 0.0000 (X_U1.DriveBuck) 0.0000
(X_U1.genPWMrst) 3.5000 (X_U1.narrowctl) 3.5000
(X_U1.XA13.YINT) 0.0000 (X_U1.XA14.YINT) 3.5000
(X_U1.XA15.YINT) 0.0000 (X_U1.XA16.YINT) 3.5000
(X_U1.XA18.YINT) 3.5000 (X_U1.XA19.YINT) 3.5000
(X_U1.XA20.YINT) 3.5000 (X_U1.XA21.YINT) .3000
(X_U1.XA22.YINT) 0.0000 (X_U1.XA26.YINT) 0.0000
(X_U1.XA28.YINT) 3.5000 (X_U1.XA29.YINT) 3.5000
(X_U1.XA30.YINT) 0.0000 (X_U1.XA32.YINT) .3000
(X_U1.XA33.YINT) 3.5000 (X_U1.XA37.YINT) 3.5000
(X_U1.buckCLKinv) 3.5000 (X_U1.DriveBoost) 0.0000
(X_U1.DriveBuckA) -1.0000 (X_U1.EmulatedIL) .1977
(X_U1.XA_DFF.MY5) 3.5000 (X_U1.XA_DFF.Qbr) 3.5000
(X_U1.XA_DFF.Qqq) 3.8435 (X_U1.DriveBoostA) -1.0000
(X_U1.enable_init) .3000 (X_U1.HSmagnified) -536.8500
(X_U1.SCSctl_init) 1.0000 (X_U1.XA200n.YINT) .3000
(X_U1.XA_DFF.Qint) 3.8435 (X_U1.rmpplusdiode) 1.0000
(X_U1.XA250n.YINT1) 3.5000 (X_U1.XA250n.YINT2) 3.5000
(X_U1.XA250n.YINT3) 3.5000 (X_U1.XA_DFF.MYVSS) 0.0000
(X_U1.XA_DFF.Qqqd1) 1.9000 (X_U1.DriveBuckAint) -1.0000
(X_U1.XA_DFF.CLKdel) 3.5000 (X_U1.XA_DFF.CLKint) 0.0000
(X_U1.XA_DFF.X2.YINT) 0.0000 (X_U1.XA_loqrst.YINT) 3.5000
(X_U1.XA_loqset.YINT) 0.0000 (X_U1.XA_minTon.YINT) 0.0000
(X_U1.XA_pwmrst.YINT) 3.5000 (X_U1.XA_pwmset.YINT) 0.0000
(X_U1.XA_Toggle.YINT) 0.0000 (X_U1.CS2CSGmagnified) -.0138
(X_U1.XA_DFF.X1.YINT1) 0.0000 (X_U1.XA_DFF.X1.YINT2) 0.0000
(X_U1.XA_DFF.X1.YINT3) 3.5000 (X_U1.XA_DFF.X3.YINT1) 3.5000
(X_U1.XA_DFF.X3.YINT2) 3.5000 (X_U1.XA_DFF.X3.YINT3) 3.5000
(X_U1.DriveBoostA_init) -1.0000 (X_U1.XA_400ns_dlyx.YINT1) 0.0000
(X_U1.XA_400ns_dlyx.YINT2) 0.0000 (X_U1.XA_400ns_dlyx.YINT3) 0.0000
**** Interrupt ****
**** Param: RELTOL = 0.001
**** Param: ABSTOL = 100e-012
**** Param: VNTOL = 100e-006
**** Param: GMIN = 1e-012
**** Param: TSTOP = 0.001
**** Param: TMAX = 2e-008
**** Param: ITL1 = 150
**** Param: ITL2 = 20
**** Param: ITL4 = 100
**** Param: AutoConverge = 0
**** Param: AutoConverge.ITL1 = 1000
**** Param: AutoConverge.ITL2 = 1000
**** Param: AutoConverge.ITL4 = 1000
**** Param: AutoConverge.RELTOL = 0.05
**** Param: AutoConverge.ABSTOL = 0.001
**** Param: AutoConverge.VNTOL = 0.001
**** Param: AutoConverge.PIVTOL = 1e-010
**** Param: ADVCONV = 1
**** Param: Current_Simulation = 3
**** Param: METHOD = 0
**** Param: TRTOL = 7
**** Param: STEPGMIN = 0
**** Param: GMINSTEPS = 0
**** Param: ITL6 = 0
**** Param: NOSTEPDEP = 0
**** Param: PTRANSTEP = 0
**** Param: GMINSRC = 0
**** Param: PSEUDOTRAN = 0
**** Param: NOSTEPSRC = 0
Time step = 301.6E-21, minimum allowable step size = 1.000E-18
V(N03843) = -1.345mV \ 13.77uV
V(HO) = -183.52V \ 5.369V
V(N04064) = -182.12V \ 6.764V
V(X_U1.CSo) = 211.13mV \ 197.69mV
V(X_U1.gateHI) = -123.00KV \ 2.369V
V(N03687) = -123.00KV \ 5.369V
V(X_U1.CS2CSGmagnified) = 1.345V \ -13.77mV
V(X_U1.conv3) = 4.479V \ 19.15uV
V(X_U1.HSmagnified) = 18.35KV \ -536.85V
V(X_M1.g1) = -10.00GV \ 5.369V
V(X_M1.g) = -10.00GV \ 5.369V
V(X_M1.s1) = -10.00GV \ 5.369V
V(X_M1.s) = -10.00GV \ 5.369V
V(X_M1.d1) = -10.00GV \ 13.00V
V(X_M1.d2) = -10.00GV \ 13.00V
V(X_M2.g1) = 873.04mV \ -275.08nV
V(X_M2.g) = 873.04mV \ -1.180uV
V(X_M2.s1) = 873.05mV \ 3.324uV
V(X_M2.s) = 873.05mV \ 3.320uV
V(X_M2.d1) = 6.242V \ 5.369V
V(X_M2.d2) = 6.242V \ 5.369V
V(X_M1.X1.d) = -10.00GV \ 13.00V
V(X_M1.X1.ox) = -10.00GV \ 7.708V
V(X_M1.X1.s) = -10.00GV \ 5.369V
V(X_M1.X1.edep) = -10.00GV \ 8.851V
V(X_M1.X1.ox0) = -10.00GV \ 5.369V
V(X_M1.X1.d1) = -10.00GV \ 13.00V
V(X_M1.X1.d2) = -10.00GV \ 13.00V
V(X_M1.X1.d3) = -10.00GV \ 13.00V
V(X_M1.X1.a) = 1.031mV \ -114.04nV
V(X_M1.X1.b) = 2.849MV \ -113.05nV
V(X_M1.X1.c) = 2.849MV \ -113.05nV
V(X_M2.X1.d) = 6.242V \ 5.369V
V(X_M2.X1.ox) = 2.836V \ 1.963V
V(X_M2.X1.s) = 873.05mV \ 3.318uV
V(X_M2.X1.edep) = 3.634V \ 2.761V
V(X_M2.X1.ox0) = 873.04mV \ 1.467uV
V(X_M2.X1.d1) = 6.242V \ 5.369V
V(X_M2.X1.d2) = 6.242V \ 5.369V
V(X_M2.X1.d3) = 6.242V \ 5.369V
I(X_U1.Econv2) = -134.48uA \ 1.377uA
I(X_U1.Econv1) = -1.835A \ 53.69mA
I(X_U1.ECS) = -488.36uA \ -37.74uA
I(X_M1.X1.E_Edg) = 4.194MA \ 874.49nA
I(X_M1.X1.E_Eds) = -8.389MA \ 2.427uA
I(X_M1.X1.E_Egs) = 8.389MA \ 16.79nA
I(X_M1.X1.E_E001) = -2.849MA \ -981.48pA
I(X_M2.X1.E_Edg) = 57.89mA \ -980.99nA
I(X_M2.X1.E_Eds) = -57.89mA \ -2.654uA
I(X_M2.X1.E_Egs) = 57.89mA \ -285.18nA
I(X_M2.X1.E_E001) = -57.63nA \ 9.59nA
I(X_M1.Lg) = 30.33KA \ -857.71nA
I(X_M1.Ls) = 25.99KA \ -2.515uA
I(X_M1.Ld) = 181.95KA \ 3.373uA
I(V_V1) = -181.96KA \ -13.00A
I(X_U1.V_FBoffs) = 465.66pA \ -152.77fA
I(X_U1.V_Iscs) = 447.93uA \ 1.915nA
I(X_U1.V_ccsense2) = 976.56uA \ 935.90uA
I(X_U1.V_ccsense1) = 976.56uA \ 935.90uA
I(X_M1.X1.V_sense) = 181.90KA \ 3.373uA
I(X_M1.X1.V_sense2) = -1.424MA \ 56.53nA
I(X_M1.X1.V_sense3) = -2.849MA \ -981.48pA
I(X_M2.X1.V_sense2) = -61.35nA \ -27.75nA
I(X_M2.X1.V_sense3) = -57.63nA \ 9.59nA
I(X_U1.H_stabilizeCS) = -447.93uA \ -1.915nA
X_U1.DB X_M1.X1.E_Edg X_M1.X1.E_Eds X_M1.X1.G_chan X_U1.M1H X_U1.M2H
( HO) -183.5200 ( LO)-1.843E-06 ( V_IN) 13.0000 (N01932) .2574
(N02110) .0180 (N02827)-3.683E-09 (N02938) .0070 (N03509) 7.0000
(N03687)-123.0E+03 (N03843) -.0013 (N04064) -182.1200 (N04096) 5.3685
(N06744) .0069 (N07445) .0069 (N07452) .0069 (X_M1.g)-10.00E+09
(X_M1.s)-10.00E+09 (X_M1.w)-27.00E-18 (X_M2.g) .8730 (X_M2.s) .8730
(X_M2.w)-27.00E-18 (X_M1.d1)-10.00E+09 (X_M1.d2)-10.00E+09
(X_M1.g1)-10.00E+09 (X_M1.s1)-10.00E+09
(X_M1.Tj) 27.0000 (X_M2.d1) 6.2416
(X_M2.d2) 6.2416 (X_M2.g1) .8730
(X_M2.s1) .8730 (X_M2.Tj) 27.0000
(X_U1.CSi) .0180 (X_U1.CSo) .2111
(X_M1.X1.a) .0010 (X_M1.X1.b) 2.849E+06
(X_M1.X1.c) 2.849E+06 (X_M1.X1.d)-10.00E+09
(X_M1.X1.s)-10.00E+09 (X_M2.X1.a) 65.08E-09
(X_M2.X1.b) 122.7E-09 (X_M2.X1.c) 122.7E-09
(X_M2.X1.d) 6.2416 (X_M2.X1.s) .8730
(X_M1.X1.d1)-10.00E+09 (X_M1.X1.d2)-10.00E+09
(X_M1.X1.d3)-10.00E+09 (X_M1.X1.ox)-10.00E+09
(X_M2.X1.d1) 6.2416 (X_M2.X1.d2) 6.2416
(X_M2.X1.d3) 6.2416 (X_M2.X1.ox) 2.8364
(X_U1.conv3) 4.4793 (X_U1.CSout) .1977
(X_M1.X1.ox0)-10.00E+09 (X_M2.X1.ox0) .8730
(X_U1.erramp) .0069 (X_U1.gateHI)-123.0E+03
(X_U1.gateLO) -3.0000 (X_U1.ground) 0.0000
(X_U1.Vstart) .0013 (X_M1.X1.edep)-10.00E+09
(X_M2.X1.edep) 3.6342 (X_U1.endTonA) 19.0760
(X_U1.enable_init) .3000 (X_U1.HSmagnified) 18.35E+03
(X_U1.XA_Toggle.YINT) 0.0000 (X_U1.CS2CSGmagnified) 1.3448
**** Interrupt ****
**** Param: ABSTOL = 1e-010
**** Param: VNTOL = 1e-006
ERROR(ORPSIM-15138): Convergence problem in Transient Analysis at Time = 578.8E-06.
Time step = 636.0E-21, minimum allowable step size = 1.000E-18
V(N04096) = 2.373V \ 2.018V
V(X_U1.gateLO) = 43.72V \ -3.000V
V(LO) = 46.72V \ -3.614uV
V(X_U1.conv3) = 149.01uV \ 114.25uV
V(X_M1.g1) = 31.91V \ 2.018V
V(X_M1.g) = 31.91V \ 2.018V
V(X_M1.s1) = 31.91V \ 2.018V
V(X_M1.s) = 31.91V \ 2.018V
V(X_M1.d1) = 42.89V \ 13.00V
V(X_M1.d2) = 42.89V \ 13.00V
V(X_M2.g1) = 10.00GV \ -4.319uV
V(X_M2.g) = 10.00GV \ -6.092uV
V(X_M2.s1) = 10.00GV \ -1.235uV
V(X_M2.s) = 10.00GV \ -1.239uV
V(X_M2.d1) = 10.00GV \ 2.018V
V(X_M2.d2) = 10.00GV \ 2.018V
V(X_M1.X1.d) = 42.89V \ 13.00V
V(X_M1.X1.ox) = 34.67V \ 4.772V
V(X_M1.X1.s) = 31.91V \ 2.018V
V(X_M1.X1.edep) = 36.30V \ 6.408V
V(X_M1.X1.ox0) = 31.91V \ 2.018V
V(X_M1.X1.d1) = 42.89V \ 13.00V
V(X_M1.X1.d2) = 42.89V \ 13.00V
V(X_M1.X1.d3) = 42.89V \ 13.00V
V(X_M1.X1.b) = 1.258uV \ -69.62nV
V(X_M1.X1.c) = 1.258uV \ -69.62nV
V(X_M2.X1.d) = 10.00GV \ 2.018V
V(X_M2.X1.ox) = 10.00GV \ 1.111V
V(X_M2.X1.s) = 10.00GV \ -1.241uV
V(X_M2.X1.edep) = 10.00GV \ 1.373V
V(X_M2.X1.ox0) = 10.00GV \ -3.238uV
V(X_M2.X1.d1) = 10.00GV \ 2.018V
V(X_M2.X1.d2) = 10.00GV \ 2.018V
V(X_M2.X1.d3) = 10.00GV \ 2.018V
V(X_M2.X1.b) = -548.75V \ 43.59nV
V(X_M2.X1.c) = -548.75V \ 43.59nV
I(X_U1.Errout) = 9.090A \ 265.00uA
I(X_M1.X1.E_Edg) = -102.62mA \ 180.07nA
I(X_M1.X1.E_Eds) = 102.63mA \ 639.53nA
I(X_M1.X1.E_Egs) = -102.62mA \ 82.50nA
I(X_M1.X1.E_E001) = -1.344uA \ -15.99nA
I(X_M2.X1.E_Edg) = 38.98MA \ -1.345uA
I(X_M2.X1.E_Eds) = -38.98MA \ -2.650uA
I(X_M2.X1.E_Egs) = 38.98MA \ 18.38nA
I(X_M2.X1.E_E001) = 548.75A \ -3.680nA
I(X_M1.Lg) = -122.94nA \ -97.58nA
I(X_M1.Ls) = -784.61nA \ -762.85nA
I(X_M1.Ld) = 708.35nA \ 860.41nA
I(X_M2.Lg) = -17.63A \ 1.364uA
I(X_M2.Ls) = -15.11A \ 2.653uA
I(X_M2.Ld) = -105.79A \ -4.017uA
I(X_U1.V_FBoffs) = 116.42pA \ -135.00fA
I(X_U1.V_Iscs) = 14.90nA \ 11.43nA
I(X_U1.V_ccsense2) = 488.28uA \ 500.13uA
I(X_U1.V_ccsense1) = 488.28uA \ 500.13uA
I(X_M1.X1.V_sense) = 708.42nA \ 860.41nA
I(X_M1.X1.V_sense2) = -629.16nA \ 34.81nA
I(X_M1.X1.V_sense3) = -1.344uA \ -15.99nA
I(X_M2.X1.V_sense) = -105.75A \ -4.017uA
I(X_M2.X1.V_sense2) = 274.37A \ -21.80nA
I(X_M2.X1.V_sense3) = 548.75A \ -3.680nA
I(X_U1.H_stabilizeCS) = -14.90nA \ -11.43nA
X_M2.X1.E_Edg X_M2.X1.E_Eds X_U1.M1L X_U1.M2L
( HO) 2.0180 ( LO) 46.7220 ( V_IN) 13.0000 (N01932) 1.2300
(N02110) .0180 (N02827) 64.41E-09 (N02938) .0070 (N03509) 7.0000
(N03687) 2.0180 (N03843) 13.74E-06 (N04064) 6.7797 (N04096) 2.3728
(N06744) .0069 (N07445) .0069 (N07452) .0069 (X_M1.g) 31.9120
(X_M1.s) 31.9120 (X_M1.w)-27.00E-18 (X_M2.g) 10.00E+09 (X_M2.s) 10.00E+09
(X_M2.w)-27.00E-18 (X_M1.d1) 42.8940 (X_M1.d2) 42.8940
(X_M1.g1) 31.9120 (X_M1.s1) 31.9120
(X_M1.Tj) 27.0000 (X_M2.d1) 10.00E+09
(X_M2.d2) 10.00E+09 (X_M2.g1) 10.00E+09
(X_M2.s1) 10.00E+09 (X_M2.Tj) 27.0000
(X_U1.tst) 0.0000 (SUPPLY_LV) 1.9673
(X_M1.X1.a)-85.60E-09 (X_M1.X1.b) 1.258E-06
(X_M1.X1.c) 1.258E-06 (X_M1.X1.d) 42.8940
(X_M1.X1.s) 31.9120 (X_M2.X1.a)-378.9E-09
(X_M2.X1.b) -548.7500 (X_M2.X1.c) -548.7500
(X_M2.X1.d) 10.00E+09 (X_M2.X1.s) 10.00E+09
(X_M1.X1.d1) 42.8940 (X_M1.X1.d2) 42.8940
(X_M1.X1.d3) 42.8940 (X_M1.X1.ox) 34.6660
(X_M2.X1.d1) 10.00E+09 (X_M2.X1.d2) 10.00E+09
(X_M2.X1.d3) 10.00E+09 (X_M2.X1.ox) 10.00E+09
(X_U1.conv3) 149.0E-06 (X_U1.CSout) .1977
(X_U1.oscQN) 3.5000 (X_U1.pkrmp) .9823
(X_M1.X1.ox0) 31.9120 (X_M2.X1.ox0) 10.00E+09
(X_U1.erramp) .0069 (X_U1.gateHI) -.9820
(X_U1.gateLO) 43.7220 (X_U1.ground) 0.0000
(X_U1.Lorst2) 3.5000 (X_U1.maxerr) .7075
(X_U1.Vstart) .0013 (X_M1.X1.edep) 36.3030
(X_M2.X1.edep) 10.00E+09 (X_U1.endTonA) 19.0760
(X_U1.XA7.YINT) 0.0000 (X_U1.XVCOA1.3) 3.6674
(X_U1.XVCOA1.4) 4.0000 (X_U1.XVCOA1.5) -4.0000
(X_U1.XVCOA1.6) .6244 (X_U1.XVCOA1.7) -2.0000
(X_U1.enable_init) .3000 (X_U1.HSmagnified) -201.8000
(X_U1.XA_Toggle.YINT) 0.0000 (X_U1.CS2CSGmagnified) -.0137
**** Interrupt ****
**** Param: ABSTOL = 100e-010
Time step = 285.4E-21, minimum allowable step size = 1.000E-18
V(X_U1.conv3) = 0V \ 114.25uV
V(X_M1.g1) = -2.502V \ 2.018V
V(X_M1.g) = -2.502V \ 2.018V
V(X_M1.s1) = -2.502V \ 2.018V
V(X_M1.s) = -2.502V \ 2.018V
V(X_M1.d1) = 8.480V \ 13.00V
V(X_M1.d2) = 8.480V \ 13.00V
V(X_M2.g1) = 516.76mV \ -4.319uV
V(X_M2.g) = 516.76mV \ -6.092uV
V(X_M2.s1) = 516.77mV \ -1.235uV
V(X_M2.s) = 516.77mV \ -1.239uV
V(X_M2.d1) = 2.535V \ 2.018V
V(X_M2.d2) = 2.535V \ 2.018V
V(X_M1.X1.d) = 8.480V \ 13.00V
V(X_M1.X1.ox) = 251.68mV \ 4.772V
V(X_M1.X1.s) = -2.502V \ 2.018V
V(X_M1.X1.edep) = 1.888V \ 6.408V
V(X_M1.X1.ox0) = -2.502V \ 2.018V
V(X_M1.X1.d1) = 8.480V \ 13.00V
V(X_M1.X1.d2) = 8.480V \ 13.00V
V(X_M1.X1.d3) = 8.480V \ 13.00V
V(X_M2.X1.d) = 2.535V \ 2.018V
V(X_M2.X1.ox) = 1.628V \ 1.111V
V(X_M2.X1.s) = 516.77mV \ -1.241uV
V(X_M2.X1.edep) = 1.890V \ 1.373V
V(X_M2.X1.ox0) = 516.77mV \ -3.238uV
V(X_M2.X1.d1) = 2.535V \ 2.018V
V(X_M2.X1.d2) = 2.535V \ 2.018V
V(X_M2.X1.d3) = 2.535V \ 2.018V
I(X_M1.X1.E_Edg) = 54.47mA \ 180.07nA
I(X_M1.X1.E_Eds) = -54.47mA \ 639.53nA
I(X_M1.X1.E_Egs) = 54.47mA \ 82.50nA
I(X_M1.X1.E_E001) = 352.26nA \ -15.99nA
I(X_M2.X1.E_Edg) = -14.14mA \ -1.345uA
I(X_M2.X1.E_Eds) = 14.14mA \ -2.650uA
I(X_M2.X1.E_Egs) = -14.14mA \ 18.38nA
I(X_U1.V_Iscs) = 0A \ 11.43nA
I(X_U1.V_ccsense2) = 976.56uA \ 500.13uA
I(X_U1.V_ccsense1) = 976.56uA \ 500.13uA
I(X_M1.X1.V_sense2) = 218.93nA \ 34.81nA
I(X_M1.X1.V_sense3) = 352.26nA \ -15.99nA
I(X_U1.H_stabilizeCS) = 0A \ -11.43nA
( HO) 2.0180 ( LO)-3.613E-06 ( V_IN) 13.0000 (N01932) 1.2300
(N03687) 2.0180 (N03843) 13.74E-06 (N04064) 6.7797 (N04096) 2.0180
(N06744) .0069 (N07445) .0069 (N07452) .0069 (X_M1.g) -2.5019
(X_M1.s) -2.5019 (X_M1.w)-27.00E-18 (X_M2.g) .5168 (X_M2.s) .5168
(X_M2.w)-27.00E-18 (X_M1.d1) 8.4802 (X_M1.d2) 8.4802
(X_M1.g1) -2.5019 (X_M1.s1) -2.5019
(X_M1.Tj) 27.0000 (X_M2.d1) 2.5348
(X_M2.d2) 2.5348 (X_M2.g1) .5168
(X_M2.s1) .5168 (X_M2.Tj) 27.0000
(X_M1.X1.a)-85.60E-09 (X_M1.X1.b)-437.9E-09
(X_M1.X1.c)-437.9E-09 (X_M1.X1.d) 8.4802
(X_M1.X1.s) -2.5019 (X_M2.X1.a) 39.91E-09
(X_M2.X1.b) 41.78E-09 (X_M2.X1.c) 41.78E-09
(X_M2.X1.d) 2.5348 (X_M2.X1.s) .5168
(X_M1.X1.d1) 8.4802 (X_M1.X1.d2) 8.4802
(X_M1.X1.d3) 8.4802 (X_M1.X1.ox) .2517
(X_M2.X1.d1) 2.5348 (X_M2.X1.d2) 2.5348
(X_M2.X1.d3) 2.5348 (X_M2.X1.ox) 1.6276
(X_M1.X1.ox0) -2.5019 (X_M2.X1.ox0) .5168
(X_U1.Vstart) .0013 (X_M1.X1.edep) 1.8884
(X_M2.X1.edep) 1.8899 (X_U1.endTonA) 19.0760
**** Interrupt ****
**** Param: ABSTOL = 100e-008
Time step = 534.9E-21, minimum allowable step size = 1.000E-18
V(N03843) = 82.73uV \ 13.74uV
V(HO) = 7.445V \ 2.018V
V(N04064) = 12.21V \ 6.780V
V(X_U1.CSo) = 197.01mV \ 197.69mV
V(X_U1.gateHI) = 4.404KV \ -982.03mV
V(N03687) = 4.407KV \ 2.018V
V(X_U1.CS2CSGmagnified) = -82.73mV \ -13.74mV
V(X_U1.conv3) = -227.24mV \ 115.25uV
V(X_U1.HSmagnified) = -744.50V \ -201.80V
V(X_M1.g1) = 10.00GV \ 2.015V
V(X_M1.g) = 10.00GV \ 2.015V
V(X_M1.s1) = 10.00GV \ 2.015V
V(X_M1.s) = 10.00GV \ 2.015V
V(X_M1.d1) = 10.00GV \ 13.00V
V(X_M1.d2) = 10.00GV \ 13.00V
V(X_M2.g1) = 2.200V \ -2.378mV
V(X_M2.g) = 2.200V \ -2.379mV
V(X_M2.s1) = 2.200V \ -2.375mV
V(X_M2.s) = 2.200V \ -2.375mV
V(X_M2.d1) = 4.218V \ 2.016V
V(X_M2.d2) = 4.218V \ 2.016V
V(X_M1.X1.d) = 10.00GV \ 13.00V
V(X_M1.X1.ox) = 10.00GV \ 4.769V
V(X_M1.X1.s) = 10.00GV \ 2.015V
V(X_M1.X1.edep) = 10.00GV \ 6.405V
V(X_M1.X1.ox0) = 10.00GV \ 2.015V
V(X_M1.X1.d1) = 10.00GV \ 13.00V
V(X_M1.X1.d2) = 10.00GV \ 13.00V
V(X_M1.X1.d3) = 10.00GV \ 13.00V
V(X_M1.X1.a) = 25.33uV \ -85.60nV
V(X_M1.X1.b) = 39.73KV \ -68.80nV
V(X_M1.X1.c) = 39.73KV \ -68.80nV
V(X_M2.X1.d) = 4.218V \ 2.016V
V(X_M2.X1.ox) = 3.311V \ 1.108V
V(X_M2.X1.s) = 2.200V \ -2.375mV
V(X_M2.X1.edep) = 3.573V \ 1.371V
V(X_M2.X1.ox0) = 2.200V \ -2.377mV
V(X_M2.X1.d1) = 4.218V \ 2.016V
V(X_M2.X1.d2) = 4.218V \ 2.016V
V(X_M2.X1.d3) = 4.218V \ 2.016V
I(X_U1.Econv2) = 8.273uA \ 1.374uA
I(X_U1.Econv1) = 74.45mA \ 20.18mA
I(X_U1.ECS) = -14.87uA \ -37.75uA
I(X_M1.X1.E_Edg) = 32.77KA \ 1.551uA
I(X_M1.X1.E_Eds) = 32.77KA \ -733.88nA
I(X_M1.X1.E_Egs) = 65.54KA \ 1.455uA
I(X_M1.X1.E_E001) = -39.73KA \ -16.80nA
I(X_M2.X1.E_Edg) = -16.60mA \ -1.610uA
I(X_M2.X1.E_Eds) = 16.60mA \ -2.385uA
I(X_M2.X1.E_Egs) = -16.60mA \ -246.50nA
I(X_M1.Lg) = -871.24A \ -97.60nA
I(X_M1.Ls) = -746.78A \ -762.86nA
I(X_M1.Ld) = -5.227KA \ 860.25nA
I(V_V1) = 5.214KA \ -13.00A
I(X_U1.V_Iscs) = -22.72uA \ 11.53nA
I(X_U1.V_ccsense2) = 488.28uA \ 497.82uA
I(X_U1.V_ccsense1) = 488.28uA \ 497.82uA
I(X_M1.X1.V_sense) = -5.227KA \ 860.25nA
I(X_M1.X1.V_sense2) = -19.87KA \ 34.40nA
I(X_M1.X1.V_sense3) = -39.73KA \ -16.80nA
I(X_U1.H_stabilizeCS) = 22.72uA \ -11.53nA
( HO) 7.4450 ( LO)-3.610E-06 ( V_IN) 13.0000 (N01932) 1.2300
(N02110) .0180 (N02827) 64.42E-09 (N02938) .0070 (N03509) 7.0000
(N03687) 4406.9000 (N03843) 82.73E-06 (N04064) 12.2070 (N04096) 2.0180
(N06744) .0069 (N07445) .0069 (N07452) .0069 (X_M1.g) 10.00E+09
(X_M1.s) 10.00E+09 (X_M1.w)-27.00E-18 (X_M2.g) 2.1998 (X_M2.s) 2.1998
(X_M2.w)-27.00E-18 (X_M1.d1) 10.00E+09 (X_M1.d2) 10.00E+09
(X_M1.g1) 10.00E+09 (X_M1.s1) 10.00E+09
(X_M1.Tj) 27.0000 (X_M2.d1) 4.2178
(X_M2.d2) 4.2178 (X_M2.g1) 2.1998
(X_M2.s1) 2.1998 (X_M2.Tj) 27.0000
(X_U1.CSi) .0180 (X_U1.CSo) .1970
(X_M1.X1.a) 25.33E-06 (X_M1.X1.b) 39.73E+03
(X_M1.X1.c) 39.73E+03 (X_M1.X1.d) 10.00E+09
(X_M1.X1.s) 10.00E+09 (X_M2.X1.a) 39.91E-09
(X_M2.X1.b) 87.34E-09 (X_M2.X1.c) 87.34E-09
(X_M2.X1.d) 4.2178 (X_M2.X1.s) 2.1998
(X_M1.X1.d1) 10.00E+09 (X_M1.X1.d2) 10.00E+09
(X_M1.X1.d3) 10.00E+09 (X_M1.X1.ox) 10.00E+09
(X_M2.X1.d1) 4.2178 (X_M2.X1.d2) 4.2178
(X_M2.X1.d3) 4.2178 (X_M2.X1.ox) 3.3106
(X_U1.conv3) -.2272 (X_U1.CSout) .1977
(X_M1.X1.ox0) 10.00E+09 (X_M2.X1.ox0) 2.1998
(X_U1.erramp) .0069 (X_U1.gateHI) 4403.9000
(X_U1.Vstart) .0013 (X_M1.X1.edep) 10.00E+09
(X_M2.X1.edep) 3.5729 (X_U1.endTonA) 19.0760
(X_U1.enable_init) .3000 (X_U1.HSmagnified) -744.5000
(X_U1.XA_Toggle.YINT) 0.0000 (X_U1.CS2CSGmagnified) -.0827
**** Interrupt ****
**** Param: ABSTOL = 1e-006
**** Param: VNTOL = 10e-006
ERROR(ORPSIM-15139): Time step = 10.89E-21 is too small in Transient Analysis at Time = 578.8E-06. Minimum allowable step size = 1.000E-18.
The device which is changing too fast is X_M2.Ld.
( HO) 2.0180 ( LO)-3.614E-06 ( V_IN) 13.0000 (N01932) 1.2300
(N06744) .0069 (N07445) .0069 (N07452) .0069 (X_M1.g) 2.0151
(X_M1.s) 2.0151 (X_M1.w)-27.00E-18 (X_M2.g) -.0024 (X_M2.s) -.0024
(X_M2.w)-27.00E-18 (X_M1.d1) 12.9970 (X_M1.d2) 12.9970
(X_M1.g1) 2.0151 (X_M1.s1) 2.0151
(X_M1.Tj) 27.0000 (X_M2.d1) 2.0156
(X_M2.d2) 2.0156 (X_M2.g1) -.0024
(X_M2.s1) -.0024 (X_M2.Tj) 27.0000
(X_M1.X1.a)-85.60E-09 (X_M1.X1.b)-68.80E-09
(X_M1.X1.c)-68.80E-09 (X_M1.X1.d) 12.9970
(X_M1.X1.s) 2.0151 (X_M2.X1.a) 39.91E-09
(X_M2.X1.b) 43.58E-09 (X_M2.X1.c) 43.58E-09
(X_M2.X1.d) 2.0156 (X_M2.X1.s) -.0024
(X_M1.X1.d1) 12.9970 (X_M1.X1.d2) 12.9970
(X_M1.X1.d3) 12.9970 (X_M1.X1.ox) 4.7687
(X_M2.X1.d1) 2.0156 (X_M2.X1.d2) 2.0156
(X_M2.X1.d3) 2.0156 (X_M2.X1.ox) 1.1084
(X_U1.conv3) 115.3E-06 (X_U1.CSout) .1977
(X_M1.X1.ox0) 2.0151 (X_M2.X1.ox0) -.0024
(X_U1.Vstart) .0013 (X_M1.X1.edep) 6.4054
(X_M2.X1.edep) 1.3708 (X_U1.endTonA) 19.0760
**** Interrupt ****
**** Param: VNTOL = 1e-005
**** Param: AutoConverge = 1
Time = 578.8E-06. Minimum allowable step size = 10.89E-21.
Resuming Simulation with the following settings
ITL4 = 354
RELTOL = 0.0086
Time step = 31.94E-21 is too small in Transient Analysis at
Time = 578.8E-06. Minimum allowable step size = 31.94E-21.
ITL4 = 1000
RELTOL = 0.05
Time step = 77.02E-21 is too small in Transient Analysis at
Time = 578.8E-06. Minimum allowable step size = 77.02E-21.
Resuming could not converge the circuit, restarting it now
V(N02827) = 64.42nV \ 64.42nV
V(N02938) = 7.000mV \ 7.000mV
V(N03509) = 7.000V \ 7.000V
V(N03843) = 13.74uV \ 13.74uV
V(HO) = 2.018V \ 2.018V
V(N04096) = 2.018V \ 2.018V
V(SUPPLY_LV) = 1.967V \ 1.967V
V(N04064) = 6.780V \ 6.780V
V(N06744) = 6.931mV \ 6.931mV
V(N07452) = 6.931mV \ 6.931mV
V(N07445) = 6.931mV \ 6.931mV
V(X_U1.CSo) = 197.69mV \ 197.69mV
V(X_U1.enable) = 300.00mV \ 300.00mV
V(X_U1.SSclmp) = 156.93mV \ 156.93mV
V(X_U1.endTonA) = 19.08V \ 19.08V
V(X_U1.EmulatedIL) = 197.69mV \ 197.69mV
V(X_U1.CSout) = 197.69mV \ 197.69mV
V(X_U1.DriveBuckA) = -1.000V \ -1.000V
V(X_U1.gateHI) = -982.03mV \ -982.03mV
V(N03687) = 2.018V \ 2.018V
V(X_U1.regout) = 7.000V \ 7.000V
V(X_U1.Vccval) = 7.000V \ 7.000V
V(X_U1.Vccgen) = 7.000V \ 7.000V
V(X_U1.SRampctl) = 1.000V \ 1.000V
V(X_U1.gateLO) = -3.000V \ -3.000V
V(LO) = -3.614uV \ -3.614uV
V(X_U1.CS2CSGmagnified) = -13.74mV \ -13.74mV
V(X_U1.SSmax) = 156.93mV \ 156.93mV
V(X_U1.rmpplusdiode) = 1.000V \ 1.000V
V(X_U1.pkrmp) = 982.30mV \ 982.30mV
V(X_U1.narrowctl) = 3.500V \ 3.500V
V(X_U1.SCSctl) = 1.000V \ 1.000V
V(X_U1.conv3) = 114.67uV \ 115.25uV
V(X_U1.HSmagnified) = -201.80V \ -201.80V
V(X_U1.unsat) = 6.931mV \ 6.931mV
V(X_U1.erramp) = 6.931mV \ 6.931mV
V(X_U1.erramp1) = 6.931mV \ 6.931mV
V(X_U1.logic1) = 7.000V \ 7.000V
V(X_U1.DriveBoostA) = -1.000V \ -1.000V
V(X_U1.maxerr) = 707.51mV \ 707.51mV
V(X_U1.CSi) = 17.98mV \ 17.98mV
V(X_M1.g1) = 2.019V \ 2.015V
V(X_M1.g) = 2.019V \ 2.015V
V(X_M1.s1) = 2.019V \ 2.015V
V(X_M1.s) = 2.019V \ 2.015V
V(X_M1.d1) = 13.00V \ 13.00V
V(X_M1.d2) = 13.00V \ 13.00V
V(X_M2.g1) = -292.15uV \ -2.378mV
V(X_M2.g) = -293.93uV \ -2.379mV
V(X_M2.s1) = -289.07uV \ -2.375mV
V(X_M2.s) = -289.07uV \ -2.375mV
V(X_M2.d1) = 2.018V \ 2.016V
V(X_M2.d2) = 2.018V \ 2.016V
V(X_U1.bstCLKinv) = 3.500V \ 3.500V
V(X_U1.Lorst2) = 3.500V \ 3.500V
V(X_U1.loQ) = 3.500V \ 3.500V
V(X_U1.genPWMrst) = 3.500V \ 3.500V
V(X_U1.DRV) = 3.500V \ 3.500V
V(X_U1.DRVdly) = 3.500V \ 3.500V
V(X_U1.buckCLKinv) = 3.500V \ 3.500V
V(X_U1.XA250n.YINT2) = 3.500V \ 3.500V
V(X_U1.triggen) = 3.500V \ 3.500V
V(X_U1.oscQN) = 3.500V \ 3.500V
V(X_U1.XA_DFF.Qint) = 3.844V \ 3.844V
V(X_U1.XA_DFF.Qqq) = 3.844V \ 3.844V
V(X_U1.XA_DFF.Qqqd1) = 1.900V \ 1.900V
V(X_U1.clkdly) = 300.00mV \ 300.00mV
V(X_U1.XVCOA1.3) = 3.667V \ 3.667V
V(X_U1.PWMQ) = 3.500V \ 3.500V
V(X_U1.HIrst) = 3.500V \ 3.500V
V(X_U1.initrst) = 3.500V \ 3.500V
V(X_M1.X1.d) = 13.00V \ 13.00V
V(X_M1.X1.ox) = 4.772V \ 4.769V
V(X_M1.X1.s) = 2.019V \ 2.015V
V(X_M1.X1.edep) = 6.409V \ 6.405V
V(X_M1.X1.ox0) = 2.019V \ 2.015V
V(X_M1.X1.d1) = 13.00V \ 13.00V
V(X_M1.X1.d2) = 13.00V \ 13.00V
V(X_M1.X1.d3) = 13.00V \ 13.00V
V(X_M1.X1.a) = -85.60nV \ -85.60nV
V(X_M1.X1.b) = -67.11nV \ -68.80nV
V(X_M1.X1.c) = -67.11nV \ -68.80nV
V(X_M2.X1.d) = 2.018V \ 2.016V
V(X_M2.X1.ox) = 1.111V \ 1.108V
V(X_M2.X1.s) = -289.08uV \ -2.375mV
V(X_M2.X1.edep) = 1.373V \ 1.371V
V(X_M2.X1.ox0) = -291.07uV \ -2.377mV
V(X_M2.X1.d1) = 2.018V \ 2.016V
V(X_M2.X1.d2) = 2.018V \ 2.016V
V(X_M2.X1.d3) = 2.018V \ 2.016V
V(X_M2.X1.a) = 39.91nV \ 39.91nV
V(X_M2.X1.b) = 44.36nV \ 43.58nV
V(X_M2.X1.c) = 44.36nV \ 43.58nV
V(X_U1.XA_DFF.CLKdel) = 3.500V \ 3.500V
I(X_U1.E_A2DA4) = -222.05e-18A \ -277.56e-18A
I(X_U1.E_DriveBuckAint) = 333.07e-18A \ 444.09e-18A
I(X_U1.E_Srampctl) = 0A \ -1.000pA
I(X_U1.Econv2) = 1.374uA \ 1.374uA
I(X_U1.E_unity) = -149.93fA \ -149.93fA
I(X_U1.E_D2AA25) = -0.999pA \ -0.999pA
I(X_U1.E_erramp) = -693.07pA \ -693.07pA
I(X_U1.Errout) = 265.00uA \ 265.00uA
I(X_U1.Esat) = -356.63e-18A \ -356.80e-18A
I(X_U1.E_D2AA24) = 222.05e-18A \ 166.53e-18A
I(X_U1.E1) = 1.600A \ 1.600A
I(X_U1.E_EN_REG) = 0A \ -50.00pA
I(X_U1.Econv1) = 20.18mA \ 20.18mA
I(X_U1.E_pkrmp) = -982.77nA \ -982.77nA
I(X_U1.E_maxerr) = -7.075uA \ -7.075uA
I(X_U1.ECS) = -37.75uA \ -37.75uA
I(X_U1.XA_loqrst.E_ABMGATE) = -6.661fA \ -7.105fA
I(X_U1.XA18.E_ABMGATE) = -6.661fA \ -7.105fA
I(X_U1.XA33.E_ABMGATE) = -6.661fA \ -7.105fA
I(X_U1.XA19.E_ABMGATE) = 2.665fA \ 3.109fA
I(X_U1.XA20.E_ABMGATE1) = -2.220fA \ -3.997fA
I(X_U1.XA250n.E_ABMGATE1) = -13.32fA \ -12.88fA
I(X_U1.XA250n.E_ABMGATE2) = 2.665fA \ 3.109fA
I(X_U1.XA_DFF.EQb) = 2.665fA \ 3.109fA
I(X_U1.XA37.E_ABMGATE) = -555.11e-18A \ -666.13e-18A
I(X_U1.XA200n.E_ABMGATE) = -10.41e-18A \ -3.469e-18A
I(X_U1.XA14.E_ABMGATE) = -6.661fA \ -7.105fA
I(X_U1.XA28.E_ABMGATE1) = -6.661fA \ -7.105fA
I(X_U1.XA29.E_ABMGATE) = -6.661fA \ -7.105fA
I(X_U1.XA16.E_ABMGATE) = -6.661fA \ -7.105fA
I(X_U1.XA_pwmrst.E_ABMGATE) = -6.661fA \ -7.105fA
I(X_M1.X1.E_Edg) = 141.10nA \ 1.551uA
I(X_M1.X1.E_Eds) = 680.80nA \ -733.88nA
I(X_M1.X1.E_Egs) = 43.31nA \ 1.455uA
I(X_M1.X1.E_E001) = -18.50nA \ -16.80nA
I(X_M2.X1.E_Edg) = -1.414uA \ -1.610uA
I(X_M2.X1.E_Eds) = -2.579uA \ -2.385uA
I(X_M2.X1.E_Egs) = -50.73nA \ -246.50nA
I(X_M2.X1.E_E001) = -4.444nA \ -3.667nA
I(X_U1.XA_DFF.X1.E_ABMGATE2) = 2.665fA \ 3.109fA
I(X_U1.XA_DFF.X3.E_ABMGATE2) = -1.600A \ -1.600A
I(X_U1.XVCOA1.XU2.E1) = -691.47mA \ -691.47mA
I(X_U1.XVCOA1.XU1.E1) = 3.099A \ 3.099A
I(X_M1.Lg) = -97.87nA \ -97.60nA
I(X_M1.Ls) = -763.10nA \ -762.86nA
I(X_M1.Ld) = 858.64nA \ 860.25nA
I(X_M2.Lg) = 1.364uA \ 1.364uA
I(X_M2.Ls) = 2.653uA \ 2.653uA
I(X_M2.Ld) = -4.017uA \ -4.016uA
I(V_V1) = -13.00A \ -13.00A
I(X_U1.V_FBoffs) = 909.50fA \ -1.819pA
I(X_U1.V_Iscs) = 11.47nA \ 11.53nA
I(X_U1.V_reg) = -500.43uA \ -500.43uA
I(X_U1.V_ccsense2) = 499.73uA \ 497.82uA
I(X_U1.VssLO) = 291.99fA \ 292.10fA
I(X_U1.V_ccsense1) = 499.73uA \ 497.82uA
I(X_U1.XA_DFF.V1) = 5.000A \ 5.000A
I(X_U1.XA_DFF.V2) = -43.02nA \ 3.844pA
I(X_M1.X1.V_sense) = 858.64nA \ 860.25nA
I(X_M1.X1.V_sense2) = 33.55nA \ 34.40nA
I(X_M1.X1.V_sense3) = -18.50nA \ -16.80nA
I(X_M2.X1.V_sense) = -4.017uA \ -4.016uA
I(X_M2.X1.V_sense2) = -22.18nA \ -21.79nA
I(X_M2.X1.V_sense3) = -4.444nA \ -3.667nA
I(X_U1.H_stabilizeCS) = -11.47nA \ -11.53nA
D_D1 D_D2 D_D3 D_D4 X_U1.DB X_U1.XA_DFF.D_D10
X_U1.XVCOA1.XU5.D1 X_U1.E_LDO X_U1.E_D2AA3 X_U1.Eboostmode X_U1.E_A2DA4
X_U1.E_curlimTH X_U1.E_DriveBuckAint X_U1.E_bkdrv X_U1.E_CURrst
X_U1.E_D2AA25 X_U1.E_erramp X_U1.E_bstdrv X_U1.Esat X_U1.E_D2AA24
X_U1.E_EN_REG X_U1.E_endBOOST X_U1.E_pkrmp X_U1.E_maxerr X_U1.E_lo_rst
X_M1.E1 X_M2.E1 X_U1.XA15.E_ABMGATE X_U1.XA_loqset.E_ABMGATE
X_U1.XA_loqrst.E_ABMGATE X_U1.XA7.E_ABMGATE X_U1.XA18.E_ABMGATE
X_U1.XA33.E_ABMGATE X_U1.XA19.E_ABMGATE X_U1.XA20.E_ABMGATE1
X_U1.XA21.E_ABMGATE1 X_U1.XA250n.E_ABMGATE1 X_U1.XA250n.E_ABMGATE2
X_U1.XA30.E_ABMGATE X_U1.XA_DFF.EQb X_U1.XA37.E_ABMGATE
X_U1.XA_Toggle.E_ABMGATE X_U1.XA_400ns_dlyx.E_ABMGATE3
X_U1.XA_400ns_dlyx.E_ABMGATE4 X_U1.XA26.E_ABMGATE X_U1.XA200n.E_ABMGATE
X_U1.XA_pwmset.E_ABMGATE X_U1.XA14.E_ABMGATE X_U1.XA28.E_ABMGATE1
X_U1.XA29.E_ABMGATE X_U1.XA16.E_ABMGATE X_U1.XA13.E_ABMGATE
X_U1.XA_pwmrst.E_ABMGATE X_U1.XA_minTon.E_ABMGATE X_U1.XA22.E_ABMGATE
X_U1.XA32.E_ABMGATE1 X_U1.XA6.E_ABMGATE X_M1.X1.E_Edg X_M1.X1.E_Eds
X_M1.X1.E_Egs X_M1.X1.E_E001 X_M2.X1.E_Edg X_M2.X1.E_Eds X_M2.X1.E_Egs
X_M2.X1.E_E001 X_U1.XA_DFF.X1.E_ABMGATE1 X_U1.XA_DFF.X1.E_ABMGATE2
X_U1.XA_DFF.X2.E_ABMGATE X_U1.XA_DFF.X3.E_ABMGATE1
X_U1.XA_DFF.X3.E_ABMGATE2 X_U1.XVCOA1.XU2.E1 X_U1.XVCOA1.XU3.E1
X_U1.XVCOA1.XU1.E1 X_U1.G_Isaw X_U1.G_35maLIMIT X_U1.G_Iss X_U1.G_I_uvlo
X_U1.G_Iramp X_M1.Gs X_M2.Gs X_U1.XA_DFF.GQ X_M1.X1.G_chan
X_M1.X1.G_RMos X_M1.X1.G_diode X_M1.X1.G_Rdio X_M1.X1.G_TH X_M2.X1.G_chan
X_M2.X1.G_RMos X_M2.X1.G_diode X_M2.X1.G_Rdio X_M2.X1.G_TH
X_U1.XVCOA1.XU6.G1 X_U1.XVCOA1.XU4.G1 X_U1.M2L X_U1.M2H
Restarting Simulation with the following settings
ITL4 = 0
ABSTOL = 0
VNTOL = 0
ERROR(ORPSIM-16550): Floating point computation failed during matrix solution. Possible solutions: 1)Ensure that all device parameters are in valid range. 2)Try using .options LIMIT
INTERNAL ERROR -- Divide by Zero, Divide
ABORTING SIMULATION
**** JOB STATISTICS SUMMARY
Node counts:
Top level (NUNODS) = 15
External (NCNODS) = 184
Total (NUMNOD) = 195
Total device count (NUMEL) = 100
Capacitors (C) = 26
Diodes (D) = 4
VCVS (E) = 10
VCCS (G) = 12
CCVS (H) = 0
Current Sources (I) = 0
Inductors (L) = 7
MosFETs (M) = 0
Resistors (R) = 27
VSwitches (S) = 0
Voltage Sources (V) = 7
Number of subcircuits (X) = 5
Matrix statistics:
Matrix size (NSTOP) = 295
Initial no. elements (NTTAR) = 892
No. elements w/ fillin (NTTBR) = 1277
No. fillins (IFILL) = 385
No. overflows (NTTOV) = 456
No. LU operations (IOPS) = 1808
Percent sparsity (PERSPA) = 98.533
Analysis statistics:
No. total time points (NUMTTP) = 44404
No. rejected time points (NUMRTP) = 6373
No. iterations (NUMNIT) = 153810
Load Threads = 12
Runtime statistics: Seconds Iterations
Matrix load = 13.57
Matrix solution = 1.48 5
Readin = .05
General setup = 0.00
CMI setup = 0.00
Setup = 0.00
DC sweep = 0.00 0
Bias point = 0.00 0
AC and noise = 0.00 0
Total transient analysis = 55.36
Output = 0.00
Overhead = .91
License check-out time = 960.63
Total job time (using Solver 1) = 55.44
