Hi Team,
It is possible to connect a thermistor with a built-in battery to the TS terminal in datasheet,
but is the temperature monitored by this terminal used only for "charging operation"?
* Does BQ25883 control using the temperature detected by TS during "battery discharge operation"?
For example, is there any control to stop the battery discharge operation outside the
usable temperature range (low temperature or high temperature)?
Shidara
