Hello team,
My customer has some questions about the pin connection of the TPS54A20.
- Does 11pin (NC) need to be connected to 20pin (SCAP)? The data sheet describes as follows in the pin functions.
“NC: No connect. This pin is not electrically connected to the IC and is included for board level reliability (BLR) purposes. Connect this pin to the SCAP trace.”
- Since 9pin (SCAP) and 20pin (SCAP) are connected inside the IC, is it okay to understand that it is not necessary to connect externally from 9pin to 20pin?
The layout example in the datasheet is as follows.(https://www.tij.co.jp/jp/lit/ds/symlink/tps54a20.pdf#page=33)
Ryotaro Fukui
