In the datasheet, the Output filtering capacitance per phase, ie Cout_Local is mentioned as 22uF typical. In the application report "Stability Considerations for LP8756x-Q1 and LP8752x-Q1" also, looks like Cout_Local used per phase is 22uF, although the C_PointOfLoad is varied as part of the analysis.
In general, the analysis result inside the app report suggested that increasing C_POL in general tended to improve the stability performance.
I was curious whether increasing the Cout_Local value used per phase beyond 22uF would also help gain some improvements on stability performance, or whether it is detrimental and hence not recommended. Can you please comment on the same?
Anoop
