Part Number: BQ78350-R2-DEVICE-FW
Hello, we are currently looking to optimize the use of the BQ78350-R2 in a cold environment. I found that we could use the TC parameter in Fuel gauging > CEDV cfg > TC.
"TC adjuststhe variationof impedancefor cold temperaturesT < TC is programmedinEDVTC Factor."
Our Bq gives a less good estimation of the battery at temperatures close to zero and we want to compensate for this use in the middle. However, we are not sure that we should change only this parameter. Do you think this is the only parameter to change? And it is not described in which unit is TC? What exactly is TC?
