Other Parts Discussed in Thread: BQSTUDIO, , BQ40Z50, BQ28Z610
Hi Team, we do have some questions for this application note.
from Section 3.1, Initial Qmax Update Criteria of Achieving, in "The Successful Learning Cycle (SLUA903). Applying a learning cycle with a TI BQ34z100-G1 fuel gauge connected to Li-Ion batteries and controlled under bqStudio V1.3.101.
1) What is [OCVFR] bit in the bq34z100-G1 case?
2) What is [REST] bit in the bq34z100-G1 case? Is [REST] related to the Extended Command StateTime()? Or is [REST] related to [OCVTAKEN] in Bit7 of the low byte in the DF/Configuration/Registers/Alert Configuration?
3) What is [QMAX] bit in the bq34z100-G1 case? Is [QMAX] related to the Extended Command LearnedStatus() bit3?
Thank you very much in advance.
-Mark
