I had a problem on the first issue of a board to support a 2S config.
I misunderstood the datasheet and during the test I found the voltage cells between VC6 and VC1 (No on VC2).
I'm releasing the new version based on the following schematics (2nd issue).
Can you confirm that the connections to the cells are correct for a 2S cells battery configuration?
Fabrizio.
