TPS65130 - EVM and Modification
Other Parts Discussed in Thread: TPS65130
Hello All,
I recently purchased a TPS65130 EVM from TI. The module is hard wired to support -5V and 8V outputs. I would like to modify the EVM to have an output of +3.3V and -3.3V. However, the EVM's resistor numbering and the datasheet's resistor numbering don't quite match up.
Before I go out and make a parts order, I wanted to know what resistor values TI suggested to make this modification as well as confirm which resistors on the EVM I should modify.
Alex
