Part Number: TPS7A20
Other Parts Discussed in Thread: TPS7A49, TPS7A30
Hello All,
We have decided to use TPS7A2033PDBVR LDO IC as voltage regulator as we have A supply voltage of 6V and we want to regulate it to 3.3V which is used to power up the MCU.
After referring the data sheet we understood that we have to give a high signal at this pin to the ("VEN")enable pin of the regulator to enable the its output.
As this regulator itself is used to regulate voltage for MCU we cannot provide high using MCU. So please suggest me with solution for my issues mentioned below,
1. So how can i give High input to the ("VEN") enable pin of regulator?
2. After referring similar kind of regulator viz. TPS7A49 and TPS7A30 we understand that the power supply signal (6V in our case) is given to both ("VIN") input pin and ("VEN") enable pin,
- Can i use the same configuration? (i.e., 6V power supply output directly is connected to ("VIN") input pin and ("VEN") enable pin).
OR
- Should i use a voltage divider?
Please Help at the earliest
Thanks and Regards
Utkarash
