Hi team,
can you help review below schematic. this is the desgin spec. thanks
Hi team,
Hi Betty,
Thank you for your post. I will review the schematics and provide any feedback by tomorrow. Thank you for your patience.
Kind Regards,
Liaqat
Hello Betty,
I reviewed the schematics and overall it looks good but I did have following comments that should be incorporated in the schematics.
- R2018 should be chosen in the range of 39K to 150K as per datasheet recommendation. Once new value is chosen for R2018, value of R2030 should be adjusted accordingly.
- Using equation 7 in the datasheet, I calculated value of C2028 to be 39pF.
Kind Regards,
Liaqat
