TPS65132: Pspice Model or TINA TSM
Part Number: TPS65132
Hello there,
Would it be possible to get the Pspice or TSM model for the TPS65132 (or equivalent)?
Thanks!
Ashwati
  • Hello Ashwati,
    I looked into it and we do no any simulation models for this older device. All the information to design a circuit around it is in the datasheet and i will be happy to answer if there are any specific questions about your application.
    Kind Regards,
    Liaqat
  • Hello Liaqat,
    Thank you for your response. If this is an older device, I want to first ensure that it is still in active in production - I am planning to incorporate it into my design to generate +/-5V. If it is planning to be phased out, is there an equivalent newer device that has a small package and similar specs (possible larger output current).
    If not, I will refer the data sheet and check back if I have any questions. Thank you.
    Ashwati
  • Hello Ashwati,
    No current plans for dis-continuing it and this device is still in active production.
    Other devices in our split rail (+/- output) portfolio are not as small a size and are either QFN or TSSOP type packages.
    Kind Regards,
    Liaqat
