Dear TI team,
I would like to know, whether connection of a charger resets the UV lockout, when load removal recovery mode is used.
What I'd like to achieve is when the battery is discharged below the UV level, it gets disconnected from the load, but while the load is still attached, it should be reset by connecting a charger (reversing the current flow). Is this in some way possible to easily achieve?
Using the UV with hysteresis has an annoying quirk that upon discharging the battery, load gets connected and disconnected couple times as the voltage on the cells recovers when load is disconnected. I'd like to get reset not upon load removal, but charger connection.
Thank you for any hints and help with this.
Jan
