Other Parts Discussed in Thread: TPS23882
HI
My customer needs 802.bt 15w 8port
VIN 12V to 54V, is there anything suitable for the product recommendation?
Thank you
Hi Gareth,
Can you confirm that the 12V spec is the DCDC input for the 50V output and NOT the PSE pass voltage on the CAT5e cable?
To be compliant to the standard, the PSE voltage range is in the 50-57V range. If you're looking to be compliant I recommend the TPS23882. You can order the TPS23882EVM and use the GUI to set each of the ports to 15W.
If looking for a 12V to 50V power supply, I recommend looking at our TI design library in the link below. Thanks!
Hi Gareth,
The TPS23882EVM is really the best circuit to copy. You can copy the same circuit design for each port.
For the DCDC, the solution I can find on TI Design library is shown below.
