According to the datasheet, battery discharge current in high impedance mode could be up to 20uA.
My goal is to reduce this current to less than 1uA. I don't need charger functionality at high impedance mode, so it would be nice to switch off the charger.
I noticed, if AUXPWR left floating, the charger does not reach maximum power, and sometimes the charger doesn't work at all. So, I put a key to connect it to VBAT in VBUS connected case.
Could you check, if I did it correctly, and it reliable path to achieve my goal? Thanks!
