BQ79616-Q1: Current Measurement through BUS BAR pins
Part Number: BQ79616-Q1
Hello TI,
I am wondering, is it  possible to measure current using dedicated Bus Bar pins?
For two different cases:
1- Low side current measurement
- I am planing to use a shunt resistor and connect 2 ports to directly BBP and BBN, than simple calculation like I = V_diff / R_shunt
2- High side current measurement in stacked operation
- Is it possible to measure current with same operation (R_shunt and simple calculation) in the top BQ79616-Q1 device's bus bar pins in a stacked operation where more than ten BQ79616-Q1 stacked.
Thank you,
All the bests,
Savas
