TPS7B84-Q1: ForLED PWM control
Part Number: TPS7B84-Q1
Hi Team,
Is it possible to use TPS7B84Q1 as LED PWM control? If I connect EN pin with the PWM input(f=500Hz)?
Frank
  • Hi Frank,
    Will you help to share more details on the application? In addition to the 500Hz, does the application have the lowest or highest duty cycle requirement? What's the output voltage and does the output current need to be controlled as well?
    Jason Song
